Question about Corega KVM 8PRO (COR-KVM-8PRO) 8-port KVM Switch
Corega KVM - Corega KVM 8PRO (COR-KVM-8PRO) 8-port KVM Switch
Corega denture adhesive
You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use....
Jun 30, 2017 | Smithkline Beecham Cars & Trucks
PCMCI Driver problem for corega KK. corega FEther PC
go to the Manufacturer Support Website and Download/Install the Current Updates for your OS.
Jul 26, 2010 | HP Computers & Internet
I need to be able to use traditional mouse and keyboard ports on one computer and usb port on second computer can i convert the KVM-2 Corega swich to do this? This switch links my present two computers but...
When you say "traditional mouse and keyboard ports" i assume that you mean the green and purple PS/2 ports. If I am correct in my assumption then this is what you can do. You can buy PS/2 to USB converter for your mouse and keyboard. A simple google search should yield you plenty of shopping results. Just make sure that you buy PS/2 to USB converters, not USB to PS/2 converters or you'll probably get the wrong thing. Everything else should just be plug-n-play from there on out. Hope this helps.
Mar 14, 2009 | Belkin Computers & Internet
Where can i get a driver for my cardbus corega cg-wlcb11v3?
Find your drivers on this page:
http://www.wireless-driver.com/wifi/corega.htm
Copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 13, 2008 | NetGear WG511 Cardbus PCMCIA 802.11g...
Wireless router
maybe there is a settings on the router wherein you can change the language settings...better contact the manufacturer of it, if possible.
Apr 27, 2008 | Computers & Internet
Corega FEther PCC_TXD driver
I need the make and model of your computer or, the type of network card you have.
David
Dec 05, 2007 | Corega (COR-00008-10) Network Adapter
Open Questions:
KVM 8pro cannot recognize mouse/keyboard I am connecting 7 computers to the changer. I have the port #7 connected to an embedded controller (PXI-8106 from National Instruments). The PXI-8106 can be powered on normally and the desktop is shown. The cursor is always shown in the middle of the screen. When I try to move the cursor in any direction, it always moves up to the top of the screen and freezes there. PXI-8106 does not recognize the keyboard either. However, it seems that the PXI-8106 is turned on with no other problems, because a shared folder of the PXI-8106 can be seen from other computers. So the only problem is the mouse and keyboard detection. If I directly connect the mouse and keyboard to the PS2-USB adaptor on the PXI-8106, they can be detected normally. In addition, even if the PXI-8106 is connected using the KVM-8pro, if a USB mouse is also connected to USB port of the PXI-8106, the controller can successfully detect the mouse that is connected through the KVM changer. Even though I am using port #7, even when other ports are used, the behavior does not change. However, when I connect port #1, it works fine. This is because the port #1 is the default active port that KVM uses when it is first turned on. If I set the port #7 as the default active port first, the PXI-8106 can successfully detect the mouse and keyboard. Since it is extra work to set the default active port to the port #7, I would rather not to do this. Also, I am currently connecting a USB mouse to the controller so that it can successfully detect the mouse through the KVM changer for some reason. However, I would like to remove the USB mouse if possible and have the switch operate as normal. Can you help me resolve this issue? Ryan
Jan 12, 2010 | Corega KVM 8PRO (COR-KVM-8PRO) 8-port KVM...
Corega KVM 8PRO (COR-KVM-8PRO) 8-port KVM Switch Logo
Top Corega Computers & Internet Experts
David Payne
David Payne
Are you a Corega Computer and Internet Expert? Answer questions, earn points and help others
