Question about Jenn-Air JEC9530 Electric Cooktop
Replacement knob KIP5A66 - Jenn-Air JEC9530 Electric Cooktop
How do I replace knob on
With your fingers around and under the rim of old knob lift up gently. You will find a flat spot on knob shaft. Replace new knob on shaft , flat spot on flat spot. GOOD LUCK FRIEND.
Sep 25, 2014 | Cooktops
Vgsu160 6b
You can try some appliance parts distributors
Jan 17, 2014 | Cooktops
Hello, My Creda cookertop ignition system has a problem . There are 4 burners on this CT. 2 diagonally across burners cannot ignite when their knobs are activated but they show sparks of ignition when the...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Feb 02, 2011 | Cooktops
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
I cannot REPLACEMENT KNOBS fOR model # 5D02
http://www.repairclinic.com/Appliance-Parts?s=t-jed8430-%3d%3dc251
This company has your knobs.
May 23, 2009 | Jenn-Air JED8430 Electric Cooktop
Problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
May 17, 2009 | Jenn-Air JED8230 Electric Cooktop
Replacement Knobs for 60's Universal Chef- Waste King Universal
I have an old Universal Chef stove - we are replacing - it is probably a mid to late 60's - the oven pan is warped - otherwise it works fine - burners, knobs, grates etc. are good - willing to let go cheap - contact Chester Koch 573-898-5508 (Elsberry, MO)
Apr 24, 2009 | Cooktops
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
SWITCH KNOB
Pull off the knob and then see if you can push the shaft in. If you can, then the knob is hitting something, preventing you from being able to push the knob in. Adjust the knob until you can push it in. If you can't push the shaft in with the knob off, then the control valve is broken and you will have to replace it.
Sep 03, 2008 | Miele 35 in. KM326G Gas Cooktop
Jenn-Air JEC9530 Electric Cooktop Logo
110 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
