Question about Ricoh Office Equipment & Supplies
Ricoh Sc 221 - Ricoh Office Equipment & Supplies
3 Suggested Answers
SOURCE: I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
(for K&Y) synchronizing detector
board.
5. Replace the laser optics housing unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
Posted on Sep 15, 2009
caroldon
  • 17130 Answers
SOURCE: Hello!
please check with your head cleaning and also your ink cartridges. if low replace and reset. If fault is still on, then reinstall the printer software and restart. . Please also check on your connection cords. See if any paper is jammed or is obstructing the mechanism, check carefully. i hope you get this fault. good day
Posted on Jul 14, 2010
Ricoh mpc4500 with sc 221 manual says(Laser synchronizing detection error: start position [K]: LD1),also have old unit with sc 220 want to know what is LD0. LD1 and LDB
Usually these errors are caused by a faulty polygon mirror motor (polygon scanner). The problem here is that the polygon causes the BICU to short out. So you would need to replace the BICU and the laser unit together to rectify this problem.
Nov 15, 2017 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Error code sc 221-3
Subcode 3 point to Cyan
ten jobs or more to see if the same SC
code is displayed:
board and the LD unit.
detector board.
board.
unit.
6. Replace the BCU.
temporary measure:
(SP 2-919-001)
Dec 12, 2012 | Ricoh Aficio CL-7100 Type P Staple 5K
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Hello! I'm writing from Romania - East Europe. A Ricoh Aficio 3224c not work at all. Error code SC 221 appears on the screen in a few seconds after the device is turned on. What to do? Thank you! J. Coman
Jul 14, 2010 | Office Equipment & Supplies
I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE ERROR READS SC 221-2
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
consecutive times.
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
(K&Y) synchronizing
detector board (the
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
is displayed:
and the LD unit.
detector board.
board.
6. Replace the BCU.
temporary measure:
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
75 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
