Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have 17.7 Briggs intex that wont start. I have a new solenoid and battery.The starter and starter wire.
2 Suggested Answers
SOURCE: craftsman 19.5 briggs & stratton mower new
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
Posted on May 03, 2009
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Bolens 42 in riding mower with briggs and stratton
Check the battery and battery lead terminals are clean (wire brush or a scotchbrite) and tight.
Still not working: - then check the battery lead connections to earth (chassis), starter solenoid and starter motor.
Feb 05, 2014 | Briggs & Stratton Garden
Briggs and stratton model 29000 starter problems
Try turning your engine by hand counter clockwise to see if it isn't under cylinder pressure..if it turns try to start...if still nothing and your battery is good you most likely have a bad solenoid..it connects the power from the battery to the starter..follow your heavy wire usually red from the positive side of your battery and from the starter..you will find it at their ends connected to two large post..it has small wires attached...that is the solenoid.. a quick way to see if it is bad is to put the switch on the run position then take a screw driver and cross it on both post,, making a direct connection bypassing the coil,,,It should crank and start your engine..if it does you need a new coil...easy job depending where yours is located..normally just below the ignition switch..under the hood or dash board..good luck..
Mar 17, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
B&S 17 hp single it only turns over til it hits compression.. good battery,starter turns over another motor ,ground wire,whats up!
The connections on the starter solenoid coil are poor. this is the two smaller wires on the solenoid but all of the wires should be removed and cleaned well at least once a year or more often if conditions warrant.
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 25 h.p. Briggs intek . The starter tries to engage but will click once and does not turn the motor. I have a new solenoid and a new battery. The starter and starter wire will get warm when tried...
sounds like starter is bound up,take it off engine and apply battery voltage to battery cable connection on starter and see if starter will turn over if not the starter is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I was riding the tractor mowing shut it off to get lunch returned 1 hr later would not start. I bought a new battery and had the starter checked all good still wont start. I get a click when i turn the key...
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
May 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
Not sure how to hook up wiring for 6.5 hp briggs with solenoid
OK
,Batt + to one of solenoid large post
Cable from solenoid lrge terminal opposit batt cable, to starter large terminal
Hot wire to start buttob wire from start button to small terminal on solenoid. Batt grd to engine.. GoodLuck, Ned
Oct 13, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Aug 11, 2009 | Briggs & Stratton Garden
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Wont start, new battery, relay good, starter good.
Check the Starter Solenoid mounted near the battery.Check it out in the dark...have someone try to start it and see if it sparks at the solenoid.connections may be loose.Also check/wiggle wiring harness to starter.
Apr 18, 2009 | 1995 Jeep Wrangler
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
24 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
