Question about Hitachi 55HDS69 55 in. Plasma Television
PIP trouble My tv when split into the PIP mode will not all me to select another input on the right side of the screen. It only says AIR. Is something hooked up incorrectly. I am using a Direct TV HDMI and DVD player on the compoment input.
The only way to get true PIP is to have a cable card. You are able to get these through Comcast for a small rental fee each month. This acts as your other signal other than your regular cable input.
Posted on Sep 17, 2008
Hitachi Tricked consumers into beleiving that true PIP was possible
It's not,you can only use any 1 source( dvd vhs ) and A cable signal via the co ax input (hence the term AIR)
Posted on Dec 09, 2007
SOURCE:
How to split my screen on my 60 inch LG plasma TV? My wife would like to watch a show while I play my PS3 at the same time?
Unless the set has a PIP feature (picture in picture) you cannot do it.
PS3 would be hooked to one input (selected for PIP) and tuner in set for the main picture.
Mar 12, 2012 | LG Televison & Video
No main video
It deffinitely sound slike it is a relay or transistor that is either burned out, short circuited, or not working. if you have a ny replacement parts, and feel daring enough, try replacing on of the boards that controls the PIP
Jan 22, 2008 | Panasonic PT-50LC13 50" Rear Projection...
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
How too make work the small pip on a 52" LCD HD tv samsung
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Dec 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
2 screens
You're talking about picture-in-picture. Simply hook up a second source or split the one cable input you have now into two leads with a splitter from somewhere like Radio Shack. Then bring up the PIP and select the input. Now you have two different things to watch each from their own channel. This wont work if you have dish... But you could watch the DVD perhaps if you hook it into one of the available inputs in the back of the Tv and select that input in PIP mode.
Good Luck!
Bill
Oct 18, 2008 | Toshiba 57H82 57" Rear Projection...
Split screen
Two sources required.....signal to both tuners or to tuner and
at least one video input then select PIP function........T.
Feb 22, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Hitachi 55HDS69 55 in. Plasma Television Logo
264 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
