Where tobuy air filters for a TGM model MWCOT18S
Where can I download a wiring schematic?
Ther might be a diagram sticked inside the panels of ur unit. Try to look there fierst. Mosstly u havr tobuy online a manual for this
Sep 21, 2014 | Heating & Cooling
2 of 3 sliding doors don`t close on tgm-69r
there is a string and a weight on the inside of each door. if you cannot find the string it may be broken. lift and remove the door from the unit, then remove two screws from both top sides of the door and the top of the door itself will come off. you can then lean the door over, the weight should slide out.
Apr 16, 2014 | Turbo Air Refrigerators
Tgm Inverter air conditioner E5 problem don't know what that means and it doesn't do anything. Please help!
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
May 07, 2013 | Heating & Cooling
TGM split MWVT12S has error notice P4
I have a model unit MWVT12S and broke the tray that collects water. Where do I can buy or if that part has warranty? my unit has 10 months of use.
Mar 24, 2013 | Heating & Cooling
I need tobuy a parts for mykw85 air- conditioner. do you have a web site, with pictures and numbers
http://www.download-manual.com/shop/Kenwood-Portable-Air-Conditir-KW85-User-Manual-pr-16741.html
Jul 23, 2011 | Kenwood KW85 Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
