Question about HP OfficeJet 6110 All-In-One InkJet Printer
I need to change out black and white cartridge on 6110 ink jet.
I don't have a manual and am not very good at this. Also my fax needs a line I can fix this, but will that hurt any thing to unplug it when I am not using fax. In other words I don't want to add another phone line. Thank you sherry
  • sherryhill2 Apr 24, 2009
    Thank you I will move ahead. Sherry
  • 20 Answers
It will not hurt your fax machine if you unplug the line!
Posted on Apr 24, 2009
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The cover that locks the black ink cartridge in
THE ROLLER THAT HOLDS THE PAPER MIGHT NOT BE HOLDING IT TIGHT AND FOR INK CARTRIDGE IT IS AN EASY FIX YOU CAN SURELY DO THAT YOU JUST NEED TO GET AND HOLD OF THE TECH AND ASK FOR THE PART.
Oct 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I replaced the black ink cartridge, Innobella, LC61Bk, all correct, for the first time in my MFC-990CW Brother fax, etc.times 3!!!! And I get "white" lines through the text. Yes, I have gone throught the...
i HAVE A lc61 SERIES BROTHER INNOBELLA AND I AM NOT ABLE TO PRINT. wHEN I TEST THE PRINTING I GET ALL COLORS BUT BLACK ON THE TRIAL DEMO I TRIED CLEANING BUT IT STILL DOES NOT WORK WHAT CAN I DO???
Oct 16, 2009 | Brother MFC-990CW COLOR INK-JET MFC Ink...
When I send a fax there is a white line through the middle of the page
If it is a laser fax, remove the cartridge and shake it up, if it is a ink jet, clean the bottom of the cartridge with alcohol and a q tip
Aug 25, 2009 | Office Equipment & Supplies
Where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Want to change it to black and white printing only.
A manual for your fax is available here, and will show you how to set your fax to monochrome mode.
Apr 14, 2008 | Brother PPF-1820C Plain Paper Inkjet Fax
Message: Remove and check ink cartridge
hi just fixed my 6110 hp by pulling out spring wire that is on right hand side where black ink cartridge gets inserted i think it was preventing a good contact
i did this after following all other help hints including cleaning heads etc and replacing with new ink now it works perfect hope this works for you too
Oct 14, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
