Question about Tools & Hardware - Others
Machine has suddenly switched off
MY FLOOR SANDER HAS SUDDENLY SWITCHED OFF WHILE SAND ING THE FLOOR.What could be the problem?
    Problem Solver:
  • 5 Answers
The motor might have a manual overload. If it does it will probably be a red push button. Just push it to reset it. If that is not the problem then I would check the cord to see if you don't have a broken wire, possible at the plug or where the wire takes a sharp bend during normal operation or storage when you are done using the machine.
Posted on Apr 25, 2009
How many Types of Power Sander?
Power sanders are really helpful tools that help the sanding job done in fewer minutes but usually takes hours by hand. The amount of effort requires while removing old peeling paint depends upon the type of sanders is used. If you pick a wrong tool, all your effort may go in vain. Different sanding machines have different specific utilities.
more details Category Sanders
Mar 14, 2018 | Tools & Hardware - Others
Ez 8 sanding machine will not start
Hi there
did it smoke or smell funny or did it just stop
either way check the drive/run capacitor that is usually
what will stop them from starting/running
Jul 15, 2014 | Clarke 07058A EZ-8 Floor Sander Expandable...
The edger runs when switched on but then shuts off when I start to sand with it. The brushes and switch have been changed on it.
check the belt and the pinion..had same problem...replaced the belt and the pinion drive, works fine
Dec 15, 2013 | Bona Edge XL Flooring Edger Sander
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
It seems the sanding table has frozen to the eccentric on my orbital clarke floor sander. Any recommendation on how to get apart. I need to replace the 4 upper bolts with rubber washers. I have tried...
Go to Americansanders.com and under the orbital sander click on it and the manual is 38 pages long, the parts explosion is towards the back of the manual but it should show you how to disassemble this tool so you can get to the bolts that you need. Let me know if you need more help
Sep 30, 2009 | Clarke Floor Sander Floor Sander Orbital...
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
Using a Clarke DU-8R drum sander, I am getting grooves in the floor from one pass to the next, running parallel to the sanding direction. I am sanding right to left as it says. Is there an adjustment to...
If the drum has the bar clamp with the 3 screws make sure the bar is set so the screws are flush when tightened down. If you reverse the bar clamp the screws will stick up a fraction and cause this grooving in your floor.
Mar 02, 2009 | Sander Industrial Original Clarke Floor...
Sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Dec 24, 2008 | National Tools & Hardware - Others
Wood working sander?
belt because it work realy good use ing the circle scraches the wood and the beld dos not
Sep 28, 2008 | Milwaukee Tool Milwaukee 6125 Sander Ro 5...
Tools & Hardware - Others Logo
132 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
