Question about Toaster Ovens
Hualilai fz31 9e switch - Toaster Ovens
My TRO651 Toaster-R-Oven does not work on any function and the blue light does not come on. I removed the right side cover and checked all the connections, then I cleaned the two sets of contacts with fine...
May not be too hard to fix. On the thermostat, you will see 5 wires coming from it. black and white on top (leave those alone), and on the bottom of the switch, there are red white and blue wires.
The white wire with the burnt connector(from use) is the problem. I had that switch apart, seen how it works. The 3 wires at the bottom (red, white, blue) is like a spst center off switch with white being the common center wire. Red is for oven, and blue is for toaster. After I rebuilt the switch the first time, and it happened again, I just bypassed switch by connecting that burnt bottom white connector, to the red timer wire connector. Oven will work, toaster will not. The oven turns off when timer runs out. Can also unplug or turn down thermostat all the way so it does not use much power when done using till timer runs out. If you have a spst(center off) switch, you can mount that too to the side panel if you find one rated for it. Just make sure the bottom white wire is used as the common center wire.
B&D will not sell that switch that is broken. I tried that before I took that switch apart. Glad I did take it apart as I am sure their new switch would have failed quickly as well.
Aug 02, 2011 | Black & Decker TRO651 Toast-R-Oven Toaster...
Intermittently won't come on, now fails to work at all.
Your timer switch is going bad and will soon stop working alltogether. If the switch is a model DKJ/1-60 you will not find one, however, there is a switch made for Delonghi that will work. Go to The Gourmet Depot website and look for switch part # 05XDE5218104600. If you have a different switch look on smallapplianceparts.com for your part or search "small appliance parts" for a few other places that sell these parts.
May 16, 2010 | Oster 6295 Toaster Oven with Convection...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
My black and decker toaster oven is less than a year old and it has a burned out smell coming from it. I feel it might be a fire hazard and I am not comfortable using it anymore for fear of fire. What can...
Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
Mar 06, 2010 | Black & Decker CTO649 Toaster Oven with...
Bravetti convectio oven. timer switch dkj/1-60. where can I get one
I have found the makers of this product and emailed them to find out if there is anyway to get service or parts. Have not had an answer yet. I think they just want to sell products PERIOD.
Feb 26, 2010 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Needs to be relaced where can i get one the timer switch
Many of these toaster ovens use a timer switch that you just cannot find in the USA. Try smallapplianceparts.com or search "small appliance parts" to find a few places that sell parts. You will need your make and model #. If your switch has a part # of DKJ/1-60 you will not be able to find one, however there is a switch made for Delonghi that will fit. the part # is 05XDE5218104600. The Gourmet Depot website has them.
Oct 04, 2009 | Bella Cucina 13049 1500 Watts Toaster Oven...
BLACK & Decker Countertop owen Model: CTO 649 does not work
Try smallappliance.com for your parts or just google search "small appliance parts" and you'll see a few places that have B&D parts.
Sep 19, 2009 | Black & Decker CTO649 Toaster Oven with...
I need a new timer switch for my Oster oven, model 6297.
If your part # is DKJ/1-60 you won't find one anywhere. There is a switch made for Delonghi ovens that will work. The part # is 05XDE5218104600. The Gourmet Depot website has them. If you have a different switch, look on smallappliance.com or search "small appliance parts" for a few other places that may have your switch. You will need the make and model # of the oven if you do not have a part #.
Jun 18, 2009 | Oster 6297 Toaster Oven with Convection...
Toster Timer Switch Broke
I had the same problem with the same exact switch DKJ/1-60. This part cannot be found anywhere but the factory and you'll have to buy 5,000 if you want one. There is another switch made for Delonghi that will work but it only has timer for toast. No 60 min. timer. The part # is 5218104600. This switch works the same way as the original but you will only have about a 13 minute timer. There is another one that has a 120 min. timer. The part # is 5218101800 for Delonghi. These switches look the same as the DKJ/1-60 but you may need to use parts from your old switch to mount these switches. Another solution to the problem is to replace the bad switch with a single pole single throw toggle switch that will handle 20 amp's on 120 volts AC. You will no longer have a timer and you will have to turn the oven on and off manually but at least you will be able to use the appliance. The above switch can be purchased at Gourmet Depot website for $10.98.
Jan 28, 2009 | Black & Decker CTO649 Toaster Oven with...
Toaster Ovens Logo
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
