Question about Epson TM-T60 Printer
Check the I/F cable connection and power of printer.
Canon ip 2770/2772 Printer error B200 slover
Solution 1:
Disconnect the power cable from the printer.
Wait 1 hour.
Connect the power cable
Solution 2:
Check and Clean Head contact pin condition of the carriage unit
Check Cable connection especially the carriage FFC
Solution 3:
Replace the Printhead
Solution 4:
Replace the power supply unit.
Solution 5:
Replace the logic board.
Dec 19, 2012 | Office Equipment & Supplies
I just bought the hp psc 1200 secondhanded and yesterday it worked. today however, the printer won't switch on. wat must i do now?
I would try to disconnect the power cable and interface cable USB or Parallel from the printer.
Then, after about a minute, connect the power cable first, and see if your printer is powering up.
If not, the problem is more likely in the printer itself.
If the printer powers up OK, then the problem could be in the interface cable or printer driver.
I would also check the PC USB port by connecting to it some flash drive.
Sometimes, it's just a power glitch. By disconnecting the power cable for 1 minute and connecting it back could resolve the problem
Mar 02, 2011 | HP Office Equipment & Supplies
Printer power on/off button does not respond and northing works
1) Connect the printer directly to the walloutlet..
2) Try with different wall outlet...
3) Check if the button is stuck inside or not..
4) Remove the power chord from he back of the printer and then press and hold down the power button for 30 sec... release the button and then plug in the power chord...
Check if the power button responds or not...
5) Check if there is any light on the adaptor or not or if the printer has any light or not...
if there is no LED light on the adaptor it is a problem with the power adaptor ..
If there is light on the adaptor as well as printer and power button does not respond it is an issue with the printer..
You must replace the printer...
Jan 24, 2011 | HP Photosmart C5380 All-In-One Laser...
There is no power in my printer what can i do?/?
Check your Cable Properly connected to the Printer.
If cable is break it will not show Power on printer.
Check another Power cable.
Aug 07, 2010 | Canon Office Equipment & Supplies
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Aug 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Self test flashes for a few seconds comes when power is connected and then power is lost
check us power cable that is ok? and also check ur usb cable which is connected with the pc. if power cable is ok then i think its ur hp power button fault. then repair ur power button. then it become ok
Aug 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
Epson CX6400. No display. no power. does the printer have an inline fuse?
1.) Unplug all cable connections ( power cable and usb cable ).
2.) Check if there's any obstructions inside the printer.
3.) While the printer is off and unplugged., press and hold the on button for 10 sec.., release after 10 sec. and connect power cable.
4.) Turn on the power.
Apr 06, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
Printer displays erro message:
1.) Turn off the power and disconnect all cable connections ( usb cable and power cable ).
2.) Check for any obstructions in side the printer.
3.) While the printer is off and cables are unplugged., press and hold the on button for 10 sec., release after 10 sec., connect the power cable., turn on the power., check if error persist.
Mar 20, 2009 | Epson Stylus CX6400 All-In-One InkJet...
1,160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
