Question about Sharp QS-2760H Calculator
Printing light - Sharp QS-2760H Calculator
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
What do symbols on top mean?
Welcome to Fixya
Half circle symbol means printer is in ready state. The printer control panel is comprised of six lights and two buttons. The lights produce patterns that identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Feb 08, 2011 | HP LaserJet P2015dn Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
MY SCANNER WILL SCAN PRINTS BUT NOT TRANSPARANCIES THE SCANNING LIGHT WORKS ON PRINTS BUT NOT TRANNYS, ANY IDEAS PLEASE
Flatbed scanners that can scan prints and transparences had two light sources.
One for normal prints (ie reflective light source, the light shines from under the glass to the print/photo and reflects off this print/photo to the optical sensor).
On a scanner that can scan transparences there is a second light source in the lid that shines through the transparences pass the glass to the optical sensor. The light source under the glass is not used in this case.
The scanning software automatically selects the right source when you select to scan prints or transparences.
Sep 06, 2009 | Umax Astra 6450 Flatbed Scanner
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
Sep 08, 2008 | HP LaserJet P2015dn Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Light printing
I would suggest using the printer's menu and checking both Direct Print->Print Quality and Direct Print->Brightness as these may be set too low or too high. Change these values, 1 at a time, and do a test print to check the print density
Dec 24, 2007 | Konica Minolta magicolor 2430 DL Laser...
Sharp QS-2760H Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
