Question about i-rocks IR-3230 Webcam
What is the difference between a simple day/night IR cameras and day/night IR cameras with IR Light?
    New Friend:
Inappropriate lighting often results in poor video quality of the surveillance cameras. This can be resolved by using the infrared illuminators along with these cameras. Since CCTV cameras are normally used for nighttime surveillance purposes and hence require enough light to capture those images in low light or at times, with no light, IR Illuminators have become a key to provide clear images under such circumstances.
Posted on Oct 16, 2013
  • 2,113 Answers
The IR lights light up your subject with light that they can't see but the camera can in order to get higher quality recordings
I. Have 2 kkmoon cameras and one of them wet black and white .what can I do to make it color again?
1. If there is not enough ambient light hitting the sensor, the camera will record in IR / night vision mode. A cooler colored ambient light may also prevent the infrared (IR) cut filter from engaging, which can cause the camera to display in black and white.
2. The camera may be recording in night vision if it is not receiving enough power.
3. Evaluate the lighting condition. If the camera is in shade or a dark area it may be displaying in night vision mode. Adjust the sun shade and re-position the camera into different or brighter lighting.
May 02, 2018 | Cameras
What is the purpose of the IR function?
IR means Infrared and is used to take pictures at night or in very dim light. If you are wanting to take pictures in low light or at night it needs to be turned on.
Sep 23, 2014 | Moultrie MFH-DGS-200 Digital Camera
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
The camera still works but when its dark in the room nothing shows on the monitor. If we turn the light on it works. It seems like the night vision feature is broken. I covered what looked like the light...
  1. It should go to automatic night vision. If this feature is not working then the answer to will a flashlight work the answer is not very well. The light will have to be on the child and a flashlight does not have much light behind it. Perhaps if you put a small lamp on a dresser that shines on the area the child is, this may work enough to keep an eye on him/her. A flashlight not so much. Hope this helps.
Regards, Tony
May 25, 2011 | Summer Infant Day Night Handheld Color...
I need a I/R setup for these binos...do you have pr can you tell me where i can get one...thanks
Hello, contact Night Vision Optics they should be able to get you one. You can make your own by using an head light. Get an IR bulb, or change the lens to IR lens. If you want to high tech then get head light will IR LED's. If the white LED's are used don't use IR lens over this white LED's because of the light spectrum is different for the the LED's than incandescent light. They will have to be changed IR LED's..GB...stewbison
Jan 09, 2011 | Kalinka Baigish 12 Russian Night Vision...
I have two ir security cameras. When it gets dark enough to require the ir to kick in, it does and then tries to go back to "day" (color) mode. It then recognizes that there is not enough light and the...
You don't mention if both cameras are malfunctioning. If so, yes it is a power problem. Each camera needs additional amperage when it switches from day to night mode. The power source is probably fine during daytime hours but can't supply the demand when the ir's kick in at night. If your power is being supplied by plug in transformers then purchase a new one with the same voltage rating (most are 24VAC) but a higher Volt/Amp rating (amperage or current). If one transformer supplies both units then purchase another identical transformer and power each camera separately. If using a power supply (transformer and power supply board) you are most likely running your cameras at 24VDC. Again, purchase another power supply with the same volltage but a larger continuous amp output. Hope this helps. Let me know if I can be of further assistance.
Jul 07, 2010 | Toshiba IK64DNA IR Day/Night Camera
Black and white picture
connect to a different video source and see if you still get blk and wht only if you still does could be a prob with your I R camera
Dec 03, 2008 | Lorex Weatherproof Color Day/Night Camera...
Moutlrie I-40 IR flash doesn't seem to work
error 020000 relates to flash/flash charging...if new, take it back.I have repaired several by replacing the IR LED flash...easier fix than the incandescent units.
Nov 09, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Using Nightmode??
the light is a flash and not meant for constant lighting. night shot is an inhanced mode for low light condition and has nothing to do with the flash
Jan 18, 2008 | Aiptek A-HD 720P Flash Media Camcorder
i-rocks IR-3230 Webcam Logo
51 people viewed this question
Top i-rocks Computers & Internet Experts
micky dee
Alan Rothery
Krishna Raju
Are you an i-rocks Computer and Internet Expert? Answer questions, earn points and help others
