Question about Janome 2049LX Mechanical Sewing Machine
I have a Janome 2049LX The manual does not tell you to oil it. I am having problems. I cleaned the feed dog. Checked everything I could. How does one oil and grease this machine. Thanks
My janome 10000 is running rough, use to run very smoothe, how do I service that?
look in the operation manual to see if you have to oil the machine or if it's one that is self oiling,, if you have to oil it, oil only the places shown in the manual.
clean under the needle plate--for lint, it collect in the feed dog area, if a small brush came with the machine use it.
clean in the bobbin area also--for lint
also use a new needle-one for the fabric being sewed
Jun 18, 2015 | Janome Memory Craft 10000
Janome Jem Silver 662 will only sew backwards. How do I adjust it so it will feed fabric correctly?
1) Check the feed dog pressure adjustment. 2) Check the feeding mechanism at the bottom. It may be too low to feed your cloth.
Feb 03, 2015 | Janome Jem Silver 662 Mechanical Sewing...
Where do i oil my janome 2049lx?
Consult manual. So e dont need it did it come with oil?
Aug 02, 2014 | Janome Sewing Machines
Janome decor excel 5018
if your talking about the feed dogs that they are not up and the fabric is not being feed, then check in your manual to see if you can manually move the feed dogs to the up position so the sewing machine will sew. here is a link for a manual if you don't have one
http://www.sewingpartsonline.com/instruction-manual-janome-decor-excel-5018.aspx
if the information about the feed dogs is not in the manual then you'll have to contact a sewing machine repair shop about having the feed dogs checked to see if there is somthing wrong with them.
Aug 21, 2013 | Sewing Machines
My janome machine model 2001.doesnot work properly it thread is loose from down side during sewing ,sometimes work properly but some time while sewing it shows same problem i was cleaning with tooth brush...
I think you may have to careful clean everything and check you havn't dropped feed dogs or changed a setting. I don't really know what you mean by the foot getting stuck, but if the feed dogs ( moving part under the cloth) are down than the cloth can't move. Also, the pressure of the foot may be too high; this can also happen accidently while cleaning.
Get a manual ( sewingmanuals.com) and double check everything. Also, check there is no thread in the thread guides as this may have been your original problem. pull a thread towards to needle
Sep 02, 2010 | Janome 4612 Sewing Machine
Where drop oil
Open the PDF for this model (Janome mechanical) and see if it is the same - http://janome.com/index.cfm/Machines/Sewing-Quilting/TB12
If not, contact Janome for a manual.
Apr 20, 2010 | Janome 2049LX Mechanical Sewing Machine
The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Jun 26, 2008 | Janome 2049LX Mechanical Sewing Machine
Feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
Mar 18, 2008 | Janome Memory Craft 10000
Janome 2049LX Mechanical Sewing Machine Logo
238 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
