Question about NetGear ProSafe GS724TP 24-Port Gigabit Ethernet Switch (GS724TP-100NAS)
Gs724tp default factory switch - NetGear ProSafe GS724TP 24-Port Gigabit Ethernet Switch (GS724TP-100NAS)
How to reset to factory default, how to know the ip default.
Default ip: 192.168.1.1
user name: manager
password: friend
Jul 08, 2014 | Allied Telesyn AT Computers & Internet
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
Need cli entry for factory default reset.. adding old switch from another site to new stack and want it clean on factory defaults
Follow these steps:
  1. Connect to the console port of the switch (9600,8,N,1)
  2. Reboot the switch.
  3. When the first line of the diagnostics tests is displayed, press CTRL-C. The system then displays a menu.
  4. Select option "i" to factory default the switch.
  5. Select option "a" to run the agent code.
Upon boot up, the switch will be in a factory default configuration.
Feb 24, 2011 | Nortel Networks Nortel Ethernet Routing...
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
NetGear PROSAFE FS728TP 24Port Ethernet Switch
The reset button only reboots the router. If so equipped, a separate "Factory Defaults" button will revert to (you guessed it) factory defaults.
Jul 21, 2010 | NetGear PROSAFE FS728TP 24Port Ethernet...
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
Need help... is there a way to reset the switch login password?
You can reset it to factory defaults in which case it will have the factory default login.
Reset — Press and hold the Reset Button for less than ten seconds to
reboot the switch. Press and hold the Reset Button for more than ten
seconds to reset the switch’s settings to the factory defaults.
Mar 14, 2010 | Linksys Cisco SLM224G Managed Ethernet...
How to reset the Password n 3510-24T Nortel switch
Hi Try the following - it should go back to factory default settings
There can be times when you need to factory reset a switch. This process can be accomplished through the CLI but if you've lost the switch password you'll need to follow a special process. This process should work for any of the Ethernet Switches (450, 460, 470) and the Ethernet Routing Switches 2500 Series, 4500 Series, 5500 (5510, 5520, 5530) Series. There is a different process to recover lost passwords on the Ethernet Routing Switch 1600 and 8600. Please note that by factory resetting the switch you will loose all configuration settings. It will be as if it just arrived from the "factory".
Follow these steps:
Jan 06, 2010 | Nortel Ethernet Routing Switch 3510-24T...
DES-3226L A1
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
Jun 20, 2008 | D-Link DES-3226L Networking Switch
NetGear ProSafe GS724TP 24-Port Gigabit Ethernet Switch (GS724TP-100NAS) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
