Carrier apu i have a carrier apu it has a panel with a series of led indicators on it in the same box as the apu is in. 2 leds are lit up 1 is sol red light the other 1 is alt hold. also the ac wont work in the sleeper and no 110vac does not work. what causes all this
bluegreenash
  • 661 Answers
SOURCE: Front Panel Connector
There should be a Front panel block on the motherboard
you should connect to it like this
Posted on Nov 15, 2007
  • 23 Answers
SOURCE: Phaser 8560 LED panel has no indication, although it appears lit
Contact Xerox @ 1 800 835 6100 and once you get to a person on the prompts. tell them your serial number and inform them your control panel is not working. They will send out a new one free of charge.
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: AC display panel lights
You will need to replace the whole in-dash A/C control unit. Changing the small bulb won't rectify your problem, as the display is LCD.
Posted on May 04, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
SOURCE: Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Posted on Aug 14, 2009
On a 2008 29 fks keystone cougar how to understand the tank and battery 'capacity' gauge located on side of refrigerator?
The tank led's indicate full...all on, 3/4 full when 3 leds are lit, 1/2 full when 2 are lit and 1/4 full when one led is lit. No leds indicate an empty tank. The battery gauge operates the same way.
Dec 05, 2016 | RVs
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
IBM xseries eserver x236 Bios problem: a yellow light( !) like this is on and IBM server can not start
Try this:
Light path diagnostics
Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
Good Luck
C2Solutions
Dec 31, 2010 | IBM eServer xSeries 236
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
  1. Turn on your TV.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
I hope that helps.
Jul 18, 2009 | Innovage Jumbo Remote Control
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Nov 04, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
