Question about Dryers
Maytag bravos dryer door
Broken latch on the door. How do I remove and replace it? Model MGD6400TQ0
dragonsthatk
  • 547 Answers
SOURCE: Door latch broken- disassemble door ??
yes if its plastic just pop it out to replace
Posted on Feb 12, 2009
hondo73162
  • 132 Answers
SOURCE: I have a maytag bravos dryer and the female side is loose
Model number ?
Posted on Oct 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
mkh5094
  • 145 Answers
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 29, 2010
Why won't the dryer door close? Little attachment on door is rattling
Type Maytag Bravos door problem into YouTube and see if the video comes up, thanks!
Jun 23, 2015 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a Maytag Bravos dryer. When I emptied the lint trap part of what was on it fell off and now my dryer won't run. I have cleared the vent and hose
When you say part of what was on it fell off was this lint or a piece of the dryer? If the switch on the door has broken the dryer will not run. In this case you will need to replace the switch / lever.
Nov 17, 2014 | Maytag Bravos 6.8 cu. ft. Electric Dryer -...
The dryer turns off after a few minutes door does not shut
Switch on the inside panel of the machine is loose, broken or worn out.
Dec 06, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos broken door latch
The best thing for you if you want to get a general idea of the machine, get your model number and go to apdepot.com Pick your brand and enter your model and you will get an illistrated breakdown part by part of the whole machine which will be very helpful.
Apr 28, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Maytag Model MGD6400TQ Front Door Won't Shut Completely
heres the aprt number for the "catch" , if you have a problem removing it i would simply push it into the door, it will fall to teh bottom , no need to worry about ti wont hurt nothin.. its meant to grab and snap into place as you push it into place, whichis why itdoesnt wnat to pull back out the same way W10111905
Jan 27, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryers Logo
24 people viewed this question
Top Dryers Experts
