Question about EnGenius DURAFON1X DuraFon 1X System Phone
Lights up no dialtone or sound - EnGenius DURAFON1X DuraFon 1X System Phone
The light does not blink, nor does the display show message waiting when there is voice mail on the phone
This model of phone does not have voicemail so you must be getting the service from another provider. The Message Waiting Indicator (MWI) is triggered by a message from the voicemail provider. If you are using a provider other then the company that provides the dialtone on your phone it is unlikely that company will be able to provide the MWI message. If you do have Voicemail with the provider of your dialtone then call and make sure they have it set up for activating you message waiting indicator there is the visual option that uses the lights on your phone and the LCD display and there is the audible option that provides a stutter dialtone when you go offhook. Some companies do both by default you will want to make sure they are providing the visual MWI alert. There are some compatiblity issues to consider but this particular phone is known to work very well with most carriers. Good Luck, I hope this helps.
Jul 05, 2011 | NorStar Meridian 8314 Corded Phone
Phone shows a voice mail but no message on phone
The phone's voice mail indicator works with the voice mail function from your phone service provider. When your line is busy or goes unanswered (depending on how it's set up), the message is recorded by your service provider at their end, and you need to retrieve it. Most systems give a "stutter dialtone" when you pick up the phone to make a call (a few short bursts of dialtone before it becomes steady) to tell you when there's a waiting message. The message waiting light on the phone lets you know in case you don't pick the phone often.
Once you pick up your voice mail the light will go out and the dialtone will go back to normal. Check with your service provider for how to do it.
May 25, 2011 | Lands Phones
Message light on Vtech cordless light won't stop blinking
The flashing message light may be telling you there is voice mail on your telephone line. If you have "home voice mail" or whatever your phone service provider calls their service, you're told of new message by a stutter dialtone. That is, when you pick up your phone to make a call, you hear two or three brief bursts of dialtone before it goes steady. Many new phone systems start flashing their message light when there are waiting messages so that you'll know about them if you don't pick up your phone. Follow whatever procedure your provider gives (usually you call a local access number) to pick up your messages, and that light should quit blinking.
Dec 26, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
I cannot get a dial tone it sound like the line is stayed open
Cellular phones to not use tone dialing. If you hear a dialtone at anytime it is simulated by your phone company however their is no dialtone.
Dec 23, 2010 | Cell Phones
Hook the phone line in for dail up and it tells me there is no dial tone.
I know it sounds foolish, but be sure the phone jack you're plugging in to actually has dialtone. Make sure the line cord you're using is good, and is firmly plugged in until the latch snaps in. Sometimes the plug may seem like it's in but isn't making a good contact.
If it still says there's no dialtone, try reinstalling the modem drivers. Then start looking for a replacement modem.
Mar 08, 2010 | Computers & Internet
No dial tone but the word "talk" appears and it lights up so I don't think the battery is dead.
I agree that the battery sounds good.
So, do you have another phone to confirm that you have dialtone coming into your home?
If so, then the two ends of your wireless phone are not communicating...
They will try to resync if you power both ends off for a few minutes (unplug the base and remove the battery from the handset).
After a few minutes off, reconnect everything and place the handset in the base.....
After 5 or so minutes, test again. If it is NOT broken inside, it should provide dialtone (if it is coming into your home).
Oct 25, 2009 | Lands Phones
Fax has stopped working on Gestenter DSC525
The modem card is faulty. It needs to be replaced.
Aug 11, 2009 | Gestetner DSc525 All-In-One Laser Printer
No dialtone on handsets, 3 beeps sound
Deregistered 4 handsets, on suggestion from FixYa, by pressing hangup & # sign.
Then reregistered to base.
May 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Dialtone problem
This sounds like a radio transmiting problem. This problem shows up first as "choppy transmit" where custimers complane of you sounding choppy or "under water". Google "KX-TGA400B choppy transmit" to find out more.
Jun 04, 2008 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
EnGenius DURAFON1X DuraFon 1X System Phone Logo
18 people viewed this question
Top EnGenius Lands Phones Experts
John L radiodude365
Bill Boyd
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
