Question about Peavey VTB1 1-Channel Amplifier
Peavey TNT 160 has no response from both inputs, only preamp in
Got given a TNT 160, guy said it only needed a fuse, I replaced the fuses and it powers up but only the preamp input produces any sound.
  • Peavey Master
  • 5,158 Answers
In my experience fuses rarely blow due to age! I suspect that whatever the guy said the problem was it was really a faulty transistors or IC in the power amp board.
You can check transistors with an Ohm meter in circuit to some extent. (the ones with a scale and needle are best for this) Look for a short between the terminals of each power transistor on the heat sink first. If any transistor sends the meter full across (both ways) you have found the fault.
Posted on May 27, 2009
What size fuse peavey XM-6
Fuse is 5 A for 120 VAC and 2.5 A for 220-230 VAC, usually 5 x 20 mm.
Oct 14, 2015 | Peavey Audio Players & Recorders
Amp blow fuses immediately when power is switched on
There could be so many things wrong with it, but personally I find the most likely problem is the power supply.
Mar 15, 2015 | Peavey TNT 115 1x15"" 600W Bass Combo...
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
I have a peavey 8.5c power amp channel one led comes as soon as signal is inputed but,no volume out of channel a very weak
One of the preamp IC's may have failed. They used LM3080N and RC4558 IC's- the 4558 you can use any 4558 as they were all high quality lo noise. The LM3080N may still be available from Mouser, i did not check them. NTE may have a replacement, but not likely to be as quiet as the original.
Even with schematic- which they do not have a provision for me to dupload, You would still end up and either buzz test starting from the output transistors and working back OR putting an audio source on the input and using a high impedance old style headphone like they used to use for ham radio (or modern earbuds connected to an impedance matching transformer low impedance winding and the high impedance winding ) you simply attach one lead to ground and then attach a test lead to the other end of the winding and work your way forward until you lose the audio signal.
Outputs of 4558 are pins 1 and 7, and inputs are 2&3 and 5&6 Do not be surprised if one input goes quiet- if both go quiet you are close. The outputs are the more important test point. These are directly in the audio path and most likely for one to have failed.
Sep 22, 2012 | Peavey Audio Players & Recorders
Peavey tnt 115 schematics
Call Peavey Customer Srervice at 877-732-8391 and they'll email it to you.
Feb 26, 2012 | Peavey Electronics Peavey Tour Tnt 115...
I have Peavey Bass amp TNT 115 combo it is 5 to 6 years old.. Recently, while playing on the stage the output went off.... and the amp is receiving the input signals but cannot get the output!!! Please...
Have you tried to open , if so does it have protection fuses or if are they still good
Does it have a fault protection indicators like leds if so
If the above don't apply check the output device but first comfirm that both vee a vcc is reaching the output devices
Dec 06, 2010 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Date a peavey amp
Contact Peavey support
Jul 09, 2010 | Audio Players & Recorders
Peavey VTB1 1-Channel Amplifier Logo
583 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
