Question about Horizon TSC 5 Treadmill Walking Belt
E1 code while walking - Horizon TSC 5 Treadmill Walking Belt
Kenmore 385.19233 shows E1 and I can not find it in the manual. What does it mean It is a sewing machine
I have found that most often the E1 code means the presser foot is not down or not all the way down (a walking foot attachment can keep it from dropping all the way). I didn't find any error codes in the Kenmore manual either. I have several Brother machines that are quite similar in design and since Kenmore doesn't actually make anything, it is probably made by Brother or Janome.
Feb 03, 2017 | Kenmore Sewing Machines
Can someone please explain what is the error E1 and how to fix it.
If you wish to get some details About treadmill repair and error codes; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
Er1 on power first treadmill will walking
You have to check the speed sensor postion. If there is any problem in the speed sensor then it can lead to the E1 message.
If you wish to get some more details about treadmill error codes and solutions then. Check the following link.
Sep 26, 2016 | Exercise & Fitness
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    E1 error after start up.
    Does the walking belt move for a brief moment, then immediately stop, followed by the E1 code? Or is there no belt movement at all when start is pressed?
    Nov 27, 2013 | Kettler treadmill Pacer
    Error E1 on star trak treadmill
    please test the speed sensor. see the diagram attached .This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board test the output voltage for input voltage terminal power if there are NOT the board is faulty . The error codes will differ between makes and models but could be e1.
    See my personal TIPS for help.
    Nov 13, 2013 | Spirit Weslo FREE SPIRIT 815 Treadmill...
    New balance 2500 treadmill shows e1 code and keeps tripping the circuit breaker after calibration.speed sensor,magnet and fuse were all checked
    The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
    Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
    The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
    If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
    Jul 16, 2010 | New Balance 2500 Treadmill
    My kenmore gas dryer M# 94836200 has a E1 code, what does this
    if you have your book that you got when purchased it has all the error codes in the back of the book,, If not call the company and they will send you a book, hope this helps you, but not to many people are going to know all the codes from all the apliances that are out there, once you get the book it will be eaiser to help to walk you thru the peocedure,,
    Aug 01, 2009 | Dryers
    E1 error code
    Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
    Good luck.
    Jun 20, 2009 | Exercise & Fitness
    Tredmill error code e1
    Trimline treadmill starts up then code E2 comes up, and the display shuts down.
    Any ideas???
    Apr 02, 2009 | Nautilus Tr300 Treadmill
    Horizon TSC 5 Treadmill Walking Belt Logo
    Top Horizon Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
    Trevor Turner
    Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
