Question about Apple iPod classic 7th Generation
When I went to turn it on it has only a white screen-nothing else there, won't sync, I've tried the 5 ways to restore and there is nothing there.
My ipod classic 120 gb just has a white screen, nothing else.
  • 342 Answers
Have you attempted to reset the ipod? It sounds more like a hardware issue, but a reset may still help. Just in case you are unfamiliar with how to perform a reset i have included step by step instructions below.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
if you can get it powered on at all with the reset, I would suggest restoring it using itunes. As before i've included the instructions below just incase you are insure on how to do this step.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If none of these steps resolve your issue, you will probably want to contact a repair service dealer of your choice. Or replace the unit all together. I hope this does resolve your issue though. Good luck :)
Posted on Apr 24, 2009
  • 502 Answers
If's still white after hard resetting and restoring and If you're out of warranty there are third party ipod repair services that will reconnect or replace the screen depending on what's wrong. There are also ipod repair tutorials that show you how to replace the iPod classic screen yourself, if you're comfortable with taking things apart. Parts are usually available on auction websites.
Posted on Jun 24, 2009
2 Suggested Answers
besthomeo
  • 108 Answers
SOURCE: how to put games in ipod classic 120 gb?
use this link on internet help
http://3gsiphone3gs.blogspot.com/2011/10/new-iphone-tutorial2.html
Posted on Oct 24, 2011
Im not getting nothing but white screen even after I do the restore thing not even a apple screen
You say you did a reset, but did you press both the home button and the on/off button for more than 5 seconds, till the apple logo comes on?
If not, try that one. When that does not work, try a reset from he Apple page, or connect the iPod to iTunes and click restore (last backup) when you did not backup for a long time, you will lose all settings and scores you made since the last backup. Reset your iPod
Feb 04, 2015 | Apple iPod touch Second Gen (8 GB,...
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
My iPhone is blocked i can`t see my home screen and the only thing that comes it the Usb showing connect to iTunes and nothing else ,i have tried all the ways to restore but still the same,can give you my...
If you've followed it's instruction to connect it to iTunes and done a sync and nothings still working on it. then it's a problem with the phone. You could try updating the firmware to a newer version and seeing if that helps.
A lot of times, restoring from a previous sync is the harm done. Sometimes, I don't know why. But an old file can corrupt and make things really hard
Aug 16, 2011 | Apple iPhone Smartphone
I have a N150 plus netbook, 6 mo. old. Using it on the internet this afternoon, it froze up; went to Task Manager, which also froze. I then rebooted and it won't boot--powers up, gives the...
In first remove battery, then one press turn on buttom, then put battery, and turn on.
if will not resaults,
reinstall operating system from CD/DVD
Jun 04, 2011 | Samsung N150 (36725723009) Netbook
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Was syncing iphone and screen went white then turned off. Will not turn back on. Tried resettting holding power and home button, still nothing. Any ideas?
try to hold both the power button and home button for 10 seconds, then release the power button and keep the home button pressed. if nothing happens after 20 seconds you have to restore your phone.
Oct 30, 2009 | Apple iPhone Smartphone
IPhone screen completely black.
Take your phone to an apple store and get a replacement.
Jul 13, 2009 | Apple iPhone 3G
HP compaq persario F700 No Display
BGA Nvidia chip GPU on motherboard needs REFLOW or REPLACEMENT.
Dec 26, 2008 | HP Compaq Presario F750US
Apple iPod classic 7th Generation Logo
164 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
