Kelvinator E04 E4 split system - Heating & Cooling
5 Suggested Answers
  • 121 Answers
SOURCE: kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Posted on Oct 16, 2008
  • 81 Answers
SOURCE: hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
  • 960 Answers
SOURCE: kelvinator split system when set
Check your filters... if they are dirty or blocked the set point temperature will be all over the place. If the filters are clean, there may be a problem with the air sensor which is attached to the evaporator on the front of the indoor unit behind the filters. Check and make sure this isnt covered with dust etc. The air sensor usually appears as a black wire mounted on a plastic mount, stuck on the coil ( Aluminium tube part) of the indoor unit behind the filters.
Posted on Jul 14, 2011
  • 14 Answers
SOURCE: I have lost the operating
http://www.kelvinator.com.au/KSE70HRB_UserManual_2009.pdf check out the site and the problem may be helpful to you.
Posted on Sep 12, 2011
Kelvinator split system heater off every 5 minutes for about 4 minutes then it comes back on and does this constantly .
Here is the free help link.
Air Conditioner Repair Help
Here is the PDF. It does not list the problem you identify but lists the contact information for Kelvinator. Bear in mind your problem could be a blockage, a bad sensor, or oddly enough, the filter needing changing. This calls for a service technician.
https://theelectricdiscounter.blob.core.windows.net/images/air-conditioner/air-conditioner/kelvinator/pictures/e_series_inverter.pdf
Jun 05, 2017 | Heating & Cooling
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
Hi, i have kelvinator split system in my house.but...
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
E04-02
E4-02 is a fuser error, thermistor or thermal fuse blown, it can only be reset in service mode F9 mode
Oct 19, 2009 | Panasonic Workio DP-3520 Copier
Dp-2010e code e04-01
E 4-01 is a fuser error that only can be reset in service mode F9 reset fuser
Jun 26, 2009 | Panasonic Office Equipment & Supplies
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator split system a/cond
Oct 16, 2008 | Heating & Cooling
Panasonic FP-D355 Error Code E04-01
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Jan 16, 2008 | Panasonic Workio DP-3530 Copier
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
