Workcentre pro 420 gives error C4 - Office Equipment & Supplies
SOURCE: How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Posted on Dec 14, 2008
  • 990 Answers
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Posted on Feb 07, 2009
  • 31 Answers
SOURCE: le code erreur j7 pour
change le drum cartridge
Posted on Feb 03, 2011
SOURCE: whats the problem on xerox
replace drum unit chip
Posted on Mar 08, 2011
babaprithi
  • 372 Answers
SOURCE: E6 error on Xerox WorkCentre
ur side or front covert is properly shut.u can cross check this by cheating the interlock switch with a screw driver.
Posted on Jun 06, 2011
How do I reset error code u4 using the control panel?
Switch off the M/C then press & hold zero button & on still when screen will display (---) then press '10' start button '1' start button. now your M/C showing 3 so you change it press '0' button then switch off &on
Oct 10, 2014 | Xerox Office Equipment & Supplies
E6 error on Xerox WorkCentre 420 PRO
Jun 06, 2011 | Xerox Office Equipment & Supplies
Is it possible to reset pro 416 out of this problem.
Limited information provided.<br /> Pressing 8 start may give you a error code. Or a 8 plus stop button.<br /> If the machine has a C4 code, this may require machine software to be installed on the machine in order to correct problems. The scanner will not operate correctly even with a new scanner. The software needs to be installed by the service representative in order to align the correct software to main board, to correct laser heas assay.<br /> Good luck.<!-- from fixya rte -->
Jun 18, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
78 people viewed this question
k24674
jasbo
jasbo
