Question about Olympus FE-130 Digital Camera
Card cover open error, but I have pics on the camera!!
I know that I need to send our camera back to the manufacturer... The little switch broke off for the card cover. Is there any way that I can access our pictures that were saved on the camera's memory (not on a card)before I try to send it back? I saw someone mention to stick something in the spot where the little switch used to be??? I have the little plastic piece that broke off and tried getting it to go back in, but that didn't seem to work. Please help! I am a teacher and these were pictures of students doing a one time only activity!
Look on ebay for a replacement door. shoundly be too expensive
Posted on Jul 29, 2008
SOURCE:
The cover on the battery and SD card opening on the camera broke off and couldn't be found on the ground. A small piece of cover and the hinge are still on the camera. When the camera is turned on a...
I imagine the only way to obtain a proper part is to send it to an approved Olympus service centre, hopefully under warranty (though I expect they would not regard this as covered).
The camera must have some way of telling that the door is open. Is there a tiny switch on the catch, or behind a little hole that something on the lid poked through? If so, perhaps you could jam it. Maybe there is a reed switch that was activated by a magnet in the lid.
I don't really see why this should be an issue for the camera to worry about, as long as things aren't falling out. My high-end Lumix pays no attention to hatches being open.
Nov 03, 2010 | Olympus FE-240 Digital Camera
I went on my camera to take a pic and it is saying the card is locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
May 20, 2010 | Canon PowerShot A430 Digital Camera
I dropped my Nikon Coolpix 4300. The camera will
This is a common error. You can only try to Format the Card. Once format, i believe this would fix the issue.
Also, try to use Camera without Card.
Unless, You need to send it for repair.
Note - Make sure batteries are all set.
Thanks.
Sep 02, 2009 | Nikon Coolpix 4300 Digital Camera
Kyocera finecam 410 "cover open"
i had a camera that did the same thing. on mine there was a little tab on the memory card cover door thing that pushed a little button. i think a piece of the little tab on mine broke off so it wasnt pushing the button so i took a little piece of paper or something and folded it really small and set it on top of the little button thing and then closed the door and that worked for me
Feb 19, 2009 | Kyocera Finecam M400R Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Card error, Laptop with vistas displaying ' insert disk' when card inserted
Not know the age of the card, is seems that it is faulty and needs to be replaced.
Sep 23, 2008 | Cameras
Error Message
Have you tried resetting your camera? To reset your camera, open the battery cover and you should see a small hole inbetween the SD card slot and the battery release switch. Then use a small narrow object (i.e. mechanical pencil with its lead extended) and press into the hole. You should feel it "click" and then hold it for about 3 seconds. Try restarting your camera.
Note: Please backup all the data on your SD card before doing this.
Hope this helps
Aug 14, 2008 | HP Photosmart R727 Digital Camera
Card cover open
Ok, you do not have to do any desodering or sodering. Take the camera cover off 7 screws. Where the switch is there is a white box where the broken switch was. Gentley lift the top of the little box and wiggle it so it breaks off. There are 2 little connectors on each side of the box. bend them up and work the rest of the box off. bend the connectors back where they were, take a smal piece of electic wire and wrap it around each of those posts. I used tweezers. No more "card door open" error. This by passes it.
Feb 15, 2008 | Olympus FE-130 Digital Camera
Olympus FE-130
on the above image you can see how I solved this problem. I used the way discribed in solution #2. I first broke off the little box and then added the little copper wire contacting the piece of iron at its left. Now my camera works again.
Apr 12, 2007 | Olympus FE-130 Digital Camera
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
May 07, 2006 | Olympus Stylus Verve / ?-mini Digital...
Olympus FE-130 Digital Camera Logo
90 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
