Question about Electrolux Dryers
Electrolux edc77550w child lock stuck... can't disable
RixsFixes
  • 2200 Answers
SOURCE: child lock
The usual way to cancel this on a Kenmore machine is to press and hold the "No heat dry" button for longer than 4 seconds. This should cancel the lock and resume normal function.
Hope this helps. Please do rate this answer. Thanks.
Posted on Aug 24, 2009
  • 8 Answers
SOURCE: the child locks are stuck it only opens from the outside
there is a slider switch on the door(between door and frame) that you can lock or unlock the child locks to prevent them from opening the door from inside but still can open door from outside----just slide the lock switch to enable or disable the child lock.
if they are stuck/stiff---you may have to remove the door panel for repair.
Usually they work free with a liitle lubricant(WD-40) to slide easier.
Posted on Jan 23, 2010
SOURCE: Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Posted on Jan 29, 2010
volpe_42
  • 35 Answers
SOURCE: my aiko tv is stuck on child lock.
You can try turning it on and pressing all the buttons down at the same time, that sometimes will reset tv's to factory.
Posted on May 20, 2010
Macmarkus
  • 2605 Answers
SOURCE: Child lock stuck in "on" position.
Hello, Welcome to fixya.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Posted on Apr 29, 2011
How do I disable the child lock on a Sharp R-891 Microwave?
It looks like from the "Home" Screem press "Information Desk" then "Useful Information" then "Child Lock" then "Set The Lock"
If you don't have a owner manual you can view online or download one here. Just put your model number in the search box
ManualsLib Makes it easy to find manuals online
Good Luck,
John
Sep 10, 2016 | Sharp Microwave Ovens
Hot point washing machine WMA76 stuck on child lock
Child Lock
?When activated all the buttons will be disabled and a child will not be
able to alter any wash programme or option settings. Once selected
this feature remains activated, even when the machine is 'off'.
To use this feature press the 'Child Lock' button and hold down for 2
seconds.The child safe icon will begin to flash.When the icon stops flashing
the feature is activated.If any of the control buttons are pressed, the child
safe icon will flash and the machine will bleep 3 times: no alterations to the
control settings will be allowed.If power is interrupted, at any time,pressing
any button will reactivate the child lock feature.
To deactivate this feature hold the 'Child Lock' button down for 4
seconds.You will then hear a bleep and the child safe icon will go out
Mar 27, 2016 | Washing Machines
Frigidaire troubleshooting key pad seems to be stuck on child lock
If you have your owner's manual, read the section on how to disable the child lock. If that doesn't work the touchpad could be defective.
Jul 17, 2014 | GE SpaceMaker Microwave Ovens
The touch control pannel on my eletrolux dishwasher will not respond and seems stuck, will not start, will not beep
Have you got any indication of error codes in the display if not check the child safety lock is not set or the disable of display is not set.I guess you have a manual it gives all the error codes in this.
Hope this helps.
May 10, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
The child locks are stuck it only opens from the outside
Jan 23, 2010 | 2000 Ford Expedition
My Buick Regal 98 back seat belt (passenger side) is stuck. Is moving a little bit but that's all, can not use it to restrain a passenger. What should I do? How to take out the original seat belt box? It's...
Is the belt twisted? If you pull it all the way out it will engage the child lock. If the child lock is engaged and the belt is twisted, you have to try to feed the belt back in far enough to disable the child lock
Aug 09, 2009 | 1998 Buick Regal
Apr 21, 2009 | Bosch Logixx WFT 2806 Front Load...
Renailt megane 2000: Back door will not open
kind of hard but it can be done but what probly happen is that the child lock is hafe and hafe not ingaged or disangeged so it's stuck
Dec 04, 2008 | 2000 Renault 181
Electorlux dishwasher flashing CL
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
Oct 24, 2008 | Frigidaire 24 in. FDB2321REC Stainless...
Dryers Logo
37 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
