Question about Roper RT21AKXKQ Top Freezer Refrigerator
It is not colling at all, and was working up until we moved it 3 doors down...carefully.
My Roper refrigerator was working, then we moved it carefully to another apartment 3 doors away and now it does not work at all. The motor is running, lights on, etc., just not cooling anything and it's been almost 24 hours now. What is it? Thanks, DSO
    Scholar:
  • 192 Answers
Silly ? but have you tryed the out let to be sure it has power, how about the breaker box. Flip the breaker back and forth a few times. some times they will look on but are on the very edge of goin off. I hope this works. you dident give me much to go on. Good luck DFD
Posted on Apr 24, 2009
How do you change door swing direction?
Refrigerators with reversible doors have mounting holes that are plugged on the opposite side. You have to remove the plug(s), remove the door and its hardware, position the door hardware to match the exposed holes and install the door with the opposite swing. Careful attention must be paid to proper door alignment so that it closes properly and seals properly.
Jun 03, 2014 | Roper Refrigerators
What if the code doesn't work for the refridgerator once we install the board? It justs beeps which means incorrect code.
Please pay careful attention to step 5
1. Press and HOLD down the alarm keypad
2. Press and hold the Freezer Temp DOWN Keypad ( - )
3. Release the Door Alarm Keypad and wait 3 Seconds
4. The control will display PE to initate the program mode
5. Entry is confirmed by pressung the Freezed temp Down Keypad (-) once more.
6. The control will display the CURRENT program code. This value should be validated with the Program CODE printed on the unit serial plate.
NOTE: If the program CODE is correct, The programming Mode is exited by closing the Refrigerator door(s).
7. Press the Refrigerator Temp UP Keypad (+) or the Refrigerator Down Keypad (-) to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temp UP keypad (+) to select the next digit
9. Once the desired program code is displayed, press and hold the Freezer DOWN (-) keypad until the progam CODE begins flashing indicating it has been saved.
Sea Breeze
Jun 08, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Is it possible to remove the front of the piece where the water and ice come out the front door
The front cover is removable but the main housing is part of the door and cannot be purchased seperate from the freezer door, so be careful......
Oct 13, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer is cold but the fridge is not?
You have to correct setting on temp that you want in the refrigerator right
Aug 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
Aug 07, 2009 | Refrigerators
Roper Side-by-Side Refrigerator Problem
Try changing the relay (in black box) on compressor.
Apr 26, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Lower part cools, upper does not
check to see if your evap motor is running / hold down the door switch with door open and your should hear it blow / if not replace the motor
Nov 26, 2008 | Roper Refrigerators
I have a new 2007 Roper Refrigerator with a top freezer. The door of the refrigerator does not shut correctly. I can see the light when I look between the freezer door and refrigerator door. If I lift and...
Generally speaking. Refrigerator door are assembled from bottom to top. Remove the cover on the top hinge of the freezer door. Remove the top hinge and lift the door to remove. You will now see the top hinge for the refrigerator door. This should be adjustable by loosening the screws and move it toward the outer edge of the refrigerator side. Tighten the screws and lock it in place. Reassemble the freezer door in the reverse order that you removed it. That should take care of the problem.
You can observe the top edge of the refrigerator door in the closed position when you have the freezer door removed.
Jul 31, 2008 | Roper Refrigerators
Icemaker does not work
check the water hose. water supply to ice maker
Sep 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RT21AKXKQ Top Freezer Refrigerator Logo
134 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
