The tray of my pioneer XC-L77 does not open - Audio Players & Recorders
2 Suggested Answers
SOURCE: The tray of my pioneer XC-L77 does not open when i
Just found your post - did you get a solution? I have already put mine into Pioneer once before and had it fixed. Now it is gone again. I am assuming it is a belt drive or something like a little fuse but haven't opened it up for a look yet.
Posted on Dec 22, 2010
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
My pioneer dv600av-s tray will close almost immediately
I have run across this the odd time, this is caused by a stretched loading belt, the reason why it opens and closes is it cannot complete the cycle to open because the belt is slipping, replacing the belt will cure this problem.
Apr 24, 2012 | Pioneer Televison & Video
Pioneer XC-IS22CD 100w CD/Tape/Radio Stereo what is the size of this
dear sir this is it all
Dimensions (W x H x D) 215 x 372 x 274 mm (S-IS22 speakers)
Dimensions (W x H x D) 160 x 300 x 237 mm (M-IS22 Amplifier)
Dimensions (W x H x D) 204 x 300 x 237 mm (XC-IS22CD head unit)
just tell me if i was helpfull
Aug 12, 2011 | Pioneer IS-22CD CD Shelf System
The tray of my pioneer XC-L77 does not open when i push the open-button. Can somebody tell me how to fix that?
Feb 10, 2010 | Audio Players & Recorders
The 5 disc console trays open but it does not stay open, it closes inmediately
Three things to check first the open close button is bad. Second is the tray sensor switch, and third is the microprocessor that controls the tray is bad. Usually it is the tray switch.
Feb 04, 2010 | Pioneer HTD-510 System
Camera Samsung L77 won't stay on anymore
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Nov 03, 2008 | Samsung L77 Digital Camera
Pioneer htz-77dv Tray Lock
We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
Jan 19, 2008 | Pioneer HTZ-77DV System
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
46 people viewed this question
 Grubhead
Grubhead
