Question about Crown Televison & Video
Tv crown 21n07 - Crown Televison & Video
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
I have a Westinghouse LD-4255VX 42 tv and when I turn it on the screen comes on with the crown symbol and then it cuts off
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Sep 01, 2014 | Westinghouse LD-4255VX 42" Edge-lit LED...
How can i put a crown ctt1506lc in game mode without remote?
I could not find an owner's manual online, so you get a generic answer. Look for an "Input" button among the TV's controls. If you don't find one, go to the TV's lowest channel number (in US TV sets, that's Channel 2). Press the Down Channel button once more. That may take you to the external video input, which I assume is what you want for "game mode."
Jul 26, 2014 | Crown Televison & Video
I need a stand for a crown tv
Contact the authorized dealer for Crown. They can help you. Gopakumar Gopalan Google
Mar 03, 2014 | Crown Beacon Flat Screen TV Stand...
Can anyone give me the remote code for crowne aire tv? thanks a lot
These are the codes to check with Crown TVs. 145 1052 1203
1147 10611032
1157 1287 1195
1012 1210 1091
If you wish to get more, check these links.
Aug 10, 2013 | Televison & Video
Code vor crown tv ctv 5555
These are the codes for Crown TV: 0053 0042
Sep 05, 2012 | Televison & Video
How to open TV lock, Panel lock and child lock of Crown Texla Television
As with all brands and models that have these features the information is never in the technical manual but is always to my experience in the owner manual--if no help there contact the company who made the unit.
Apr 16, 2012 | Crown Televison & Video
My crown tv 14 asks for a key on the screan. What can i do?
Hi , the key on the blue screen of all crown portable tvs is between 540 and 560, usually its 551 or 552 8)
Mar 03, 2011 | Crown OD-TV125B 5 in. Portable Television
I need a crown
Try website 1-800-Remotes Factory original.To buy an exact remote.
Feb 16, 2010 | Disney 13" TV
Televison & Video Logo
Top Crown Televison & Video Experts
Jay Plesset
Paul Bade
Are you a Crown Televison and Video Expert? Answer questions, earn points and help others
