Question about Motorola MJ270R Two Way Radio
I HAVE A FEW MJ27OR WALKIES THAT WE GOT BUT THEY ARE SET FOR LISTEN ONLY ON A FEW AND TALK ONLY ON A FEW. HOW DO I GET THIS OFF AND BACK TO NORMAL?
3 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: motoroala mj270 walkie talk
Here is a link to the MJ270 user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MJ%20Series%20User%20Guide%2012-12-08%20KEM-PK14190-74.pdf
Best regards.
Posted on Jul 15, 2012
eradiostore
  • 1654 Answers
SOURCE: manual for motorola two way radio walkie talk about mj270
Best regards.
We have three Uniden walkie talkies - two of them have a symbol of a walkie talkie above the channel - these two will not talk to each other - but they talk to the one without the symbol - how do I ge
Sounds like the PL tone is set on the two, with different tones. Go to the menu, find the tone screen, and turn off the tone (or set them all to the same tone). That should fix the problem!
Oct 03, 2014 | Uniden Radio Communications
What does Mon mean on a walkie talkie?
"Mon" is short for "Monitor" and is usually a feature that allows you to momentarily break the squelch (signal filter) and hear anything being transmitted on that frequency. That includes static if there's no transmissions. It allows you to listen for a weak signal that can't break the squelch threshold you have set. Some radios allow you to lock it open by pressing and holding the MON button for a few seconds. Turn the feature off my doing the same thing.
Jul 03, 2014 | Motorola Walkie Talkies 23-mile Range...
I can talk but cant hear
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
My walkie talkie motorola em1000 have buzzing sound when another walkie is talking. and have buzzing sound when pressing the button.
Just a few thoughts: It is possible you have a bad (blown) speaker on the buzzing radio or the radio has another problem.
A few things you might try include: 1) Cleaning your battery contacts, 2) trade batteries with the known good unit and see if the problem is solved, if so replace the battery, 3) check the mic and speaker holes on both units to be certain they are free of debris and/or stickers covering the holes. 4) if none of these solve the problem, then your radio likely needs retired/replaced.
Best regards.
Dec 30, 2013 | Motorola Walkie Talkie 2-Way Radio
I cant talk ans listen on wotorola fv150 anymore
You can find a copy of the user guide at shop.giantintl.com/Manuals.asp
Check both your batteries and your programming. Be certain both radios are set to the same freq. and code. Turn off any other special features and try the radios in a very basic mode, then add features back in once you have regained communication.
Best regards.
Mar 27, 2013 | Motorola Walkie Talkie 2-Way Radio
I have a walkie talkie i can talk to the reciever and hear it but i cant talk back from the reciever
Check your private line code (aka tone code or interference eliminator code). One of your radios possibly has it set differently than the other.
Sep 24, 2011 | Radio Communications
Do the Uniden walkie talkie (UHO36SX) on listening mode (RX) normally give out a loud rushing noise? It would be impossible to have it on in a quiet place waiting for someone to talk.
No, the radios should be silent (squelched) when not receiving a transmission. Appliances (computers, televisions, even refrigerators) can generate enough "hash" to break the squelch and give you that "rushing" noise. Make sure that the radios are at least 4 or 5 feet apart, and try moving them to different locations to clear up the problem.
Bill B
Jun 01, 2010 | Radio Communications
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Oct 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Problem unknown
Hello rixonsusu,
In situations where one radio cannot talk to another radio the problem is often caused by improper setting of the radio's Continuous Tone Coded Squelch System (CTCSS), which Motorola calls "Privacy Codes." (Other manufacturers might use different names, such as Kenwood calling this feature "Quiet Tones.")
When CTCSS is activated your radio's receiver will be muted unless the radio receives a signal from another radio using the required Privacy Code. This prevents you from having to listen to other user's conversations on what can be busy channels with a lot of activity.
In one of your radios has CTCSS enabled and the other does not, or if the other radio is set to the wrong CTCSS tone, the situation you describe will occur: one radio will be able to talk to the other, but that radio will not be able to talk back.
Make sure both of your radios are set to the same CTCSS privacy code or that CTCSS is turned off on both radios.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Feb 04, 2008 | Motorola Walkie Talkie 2-Way Radio
Motorola MJ270R Two Way Radio Logo
61 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
