Pretty sure you need to replace the drum cartridge. When the drum blade goes bad or edges of the drum go bad it will cause this issue. You can stop a copy as it is passing thru and compare the edge as it is being transferred to the drum and what is on the paper to see what I am talking about.
I can be more specific if necessary
Thanks
TankMurdock
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 800 Grayscale Copier
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I...
(More)
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I powered it on and it went from warming up to call for service error code F103. I would like to try to fix this but need some instruction. I think I have determined it is a hard drive problem. This was the explanation provided for the same problem on a Toshiba 282 (which appears to be the same copier branded differently). Where is the hard drive? What type of hard drive should is required for replacement? Once I have physically replaced it; Now what? Help!
