Question about JVC GY-HD110U Camcorder
JVC GY-HD110U won't turn on with battery power only AC power.
I have new fully charged batteries but my JVC GY-HD110 will not power up.
There is an issue with the a small yellow part of the AC plug breaking off in the camera. The camera thinks it's still plugged in, so it won't run on the battery. If you can get a small tool to fit into the inlet you can break the piece up and pull the parts out. I haven't had any luck with it, but read others doing it.
Posted on Oct 02, 2009
  • jjurko Jun 30, 2011
    Yup if the yellow cap on the end of the AC adapter breaks off it will not pull from the battery.
    I fixed it by putting a very light layer of crazy glue on the tip of the AC adapter end and then I pushed it into the input on the JVC and held it for a minute. Then I let it dry for a half hour.
    It pulled right out with the cap attached to the end. A little crude but it worked :) Now I can use my battery packs again :)
    Hope that helps.
    John
IT SHOWING A WIERD BLUE SCREEN THAT COMING FROM THE CAMERA
How old is your camera. Please dont attempt to repair yourse
Nov 24, 2014 | JVC GY-HD110U Camcorder
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Can't tranfer videos from camera to computer
MOD Converter is a powerful and practical windows software helping you convert .mod .tod files recorded by camcorders JVC (.mod and .tod), Panasonic (.mod), Canon (.mod) to computer. The output video and audio formats include: MPG, AVI, WMV, MP4, MOV, 3GP, RM, FLV, SWF, MP3, M4A, WAV, etc.
Aug 15, 2009 | JVC GY-HD110U Camcorder
JVC GY-HD110U
discharge your batt. fully. charge your batt. on 3phase current. dont remove in middle, give time for your batt. to charge fully
ues JVC original batt.
Jun 18, 2009 | JVC GY-HD110U Camcorder
New BN-V428U battery
BATTERY TIPS
Now a days in LITHIUM BATTERIES are used no memory effect
always charge battery for 16 hours when first use new
never keep ur battery fully discharged for long time when u store ur camera always keep it half charged or fully charged when storing for longer period
it is good to fully discharge once in a month but dont make it ur habit
pls rate me FIXYA for help
Apr 13, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Pixel
the camera have a service menu that fixed it
first you must be in 24p mode for this operation
press and holding simultaneous the focus assist button(the one on the camera body)and the menu/status button for at least 5 seconds.
you see and advanced menu where the second line says CAMERA 1.
move the cursor down and push the shutter wheel to enter that menu and now you have a list with the six item being PIXEL COMPEN.
move down and select that item, the word CANCEL blinks.
change it to EXECUTE and push again. it takes about 10 seconds or so to perfom the operation and then tells you to power off the camera.
YOU ARE DONE!!
Feb 20, 2008 | JVC GY-HD110U Camcorder
The batterys are charged, but nothing happens when I turn it on.
This camera and the model before it have a problem with inrush current opening a safety fuse on the DC-DC converter board. If this is the case, JVC will replace the SMD fuse with a modified part number, this should resolve the problem. Please be sure the camera is off before attempting to change the battery, this can also cause this problem. Good Luck. Joe Weibel customelectronics.org
Feb 25, 2007 | JVC GY-HD100 Mini DV Digital Camcorder
JVC GY-HD110U Camcorder Logo
403 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
