Question about Pentair MAXITHERM 333K BTU PROPANE GAS POOL HEATER LOW NOX -
Pool heater will not come on
Press pool button but no blower comes on and it goes to service heater
  • 640 Answers
There is an extensive troubleshooting flow chart in the owners manual for these pool heaters that will answer this question better than we could. It has many steps that you must check to come to a solution. The link below is to a pdf of the manual. Try that and I bet you find your solution.
http://www.backyardcitypools.com/Pool-Heaters-Main.htm
Posted on Aug 12, 2010
My sta rite max e therm will not light
first ofall r 13 128 isnot an error code! blower comes on closes airswitch, then goes through all safeties, etc. need more info please ?
Nov 10, 2013 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
Get several codes , when i turn it on all the lights come on and display has a 888, then a 180. all goes off, receive a code sf 1, then an r4
Check your stack flu sensor. Sensor can not be jumped. As soon as the heater fires hold down the pool or spa button until the stack temp appears. At 500 degrees the heater will shut off giving a code. The heater should not restart. I would also check for wire damage based on the description of your issue and the board restarting on it own. You may also have damage to the "user interface board" , hard to say with out on site trouble shooting.
Jun 04, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
I have a Pentair minimax 250k electronic. Opened pool today and when I turned power on to the heater, it won't get through startup sequence. Dashed lines flash, then 888 and service light comes on. ...
Most of the time I have found the problem to be the thermistor. It is located on the water manifold of the heater. Usually the panel lights, flashes then to 888 and back to dashed lines. SW light is green, and service light is red. It costs 25 to 45 dollars, and takes 5 minutes to repair. New thermistor looks identical to old so replacing it is very easy.
thanks please let me know if this was helpful
May 21, 2011 | Pentair Minimax NT Heater
Heater goes on for about 30second and goes off and the lights goes on services heater
Heater is probably not coming on. What you hear running for about 30 seconds is the blower. After they blower comes on you should hear a obvious click. That is the igniter coming on. If you don't hear the click you have an electrical problem. If you do hear the click then either the heater is not getting gas - check the valves inside and outside the heater - or the flame sensor is not working correctly.
Good Luck
Apr 16, 2011 | Pentair MasterTemp 400000 BTU Pool and Spa...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
I have a Pentair minimax NT heater and it reads OFF when trying
Often it is a bad iginition module. Have you checked it?
Aug 10, 2009 | Pentair Minimax NT Heater
Pentair MAXITHERM 333K BTU PROPANE GAS POOL HEATER LOW NOX - Logo
330 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
