Question about Toshiba Satellite A100-S8111TD Notebook
IDE#0 ERROR - Toshiba Satellite A100-S8111TD Notebook
    Sergeant:
  • 239 Answers
Usually the HDD is set on IDE #0.
The PXE error appears if the notebook tries to boot up from the LAN but the cable is not connected or there is no possibility for LAN booting.
In my opinion there is something wrong with the HDD or the BIOS cannot recognize the HDD correctly. I would recommend checking the HDD pins. Furthermore you should change the booting order in the BIOS.
Posted on Apr 24, 2009
3 Suggested Answers
nenalex2002
  • 134 Answers
SOURCE: IDE #0 ERROR
It sounds like there is a hard-drive problem. To help you further I would need your complete laptop model number. If your hard drive is indeed dead, most likely it's not too difficult to replace and a 2.5" hard drive is not that expensive.
Hope this Helps
Posted on Nov 02, 2007
  • 49 Answers
SOURCE: toshiba satellite error code ide #0 error
IDE #0 is where your hard drive connects to your computer's motherboard. You may be able to connect your hard drive to IDE#1 or you will have to have your motherboard replaced.
Posted on Jun 29, 2009
Ide 0 error I have a 2535 and it displays on the screen ide error #0 replace disk and press any key
Replace the hdd and reinstal windows or go into the bios and find out why the hdd is not available.
Jul 23, 2014 | Toshiba Computers & Internet
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
My pc show IDE #0 ERROR
IDE errors are particularly nasty. If you can get it to boot up, run CHKDSK/F straight away to try and recover your data.
Dec 21, 2010 | Toshiba Computers & Internet
My Toshiba 2515CDS has an IDE #0 error
to remove the error go to bios setup and change the sata mode ich to IDE.
Apr 08, 2010 | Toshiba Satellite 2515CDS (PAS251U-S6CW8)...
Toshiba satellite error code ide #0 error
Jun 28, 2009 | Toshiba P000392200 - Satellite A40, A45...
Media Test Failure, Hardware Problem?
reset your BIOS settings to default, to do this go into BIOS screen and choose return to default settings.
Jun 17, 2009 | Acer Aspire 3680 Laptop
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
OR
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
OR
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Sony VAIO laptop; DVD-R not reading disks
Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
If no joy then:
Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Jul 05, 2008 | Computers & Internet
IDE #0 ERROR
Hope this Helps
Nov 02, 2007 | Toshiba Tecra M2 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
353 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
