Question about Canon PIXMA MP600 all-In-One InkJet Printer
The paper is jammed using either tray. How I could fix it? The printes is a Canon PIXMA MP610
  • faguilabarra Apr 24, 2009
    Thank you very much for your attention and prompt response.
    The problem already was fixed ( The protection of an earphone was fallen among the rollers )
    President:
  • 1,996 Answers
Please go to this link and enter "paper jam" as the support question and you will be taken to a series of support solutions for this error.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 24, 2009
Error 6A00
Hello and Welcome to FixYa!
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MP610 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
I hope it will be surely helpful for you. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Apr 19, 2011 | Canon MP610 Photo All-In-One Printer
Printer was working O/K last time I used it, turned it today and it tells me that there is a printer error and shows code A600. Have tried turning off and on as suggested and this has not worked. please...
Hello and Welcome
I am Angel Bird and i will be assisting you regarding the issue
The A600 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,It usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.The purge unit,called a spittoon assembly in an Canon, HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing,That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow, Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
If you didn't get it and have confusion to solve it yourself then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution was helpful for you. Please Rate my solution it if it helps you.
Thanks & keep usin FixYa
Mar 13, 2011 | Canon PIXMA MP610 InkJet Printer
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error no paper in cassette, but there IS paper in the cassette
i closed the front facing paper tray flap (where the paper should end up after being printed) and hit print again. for some reason it was able to process that there was paper in the top tray, and proceeded to print. strange.
Apr 17, 2010 | Canon PIXMA MP610 InkJet Printer
Error 6A00 appears. Will not print. Cannot find
Try it maybe
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
I have a paper jam with my MP610 printer its the rear feed tray i got the paper out intact (1 piece) it still tells me there is a jam. Is there a sensor i may have tripped? I bought the printer 3 weeks ago
My hp laserjet 4250n was working perfect but when i give above 50 number of print it's start to use it it gives messege says paper jam in 13.01.00 help me how to fix this problem
Sep 15, 2008 | Canon Office Equipment & Supplies
Canon PIXMA MP600 all-In-One InkJet Printer Logo
83 people viewed this question
old marine
old marine
