Question about Roper RAX4233PQ Top Load Washer
Drive link is broken
I know how to remove the shell. How do I change the drive link?
  • 4 Answers
Whirlpool 7 speed 2 cycle will not spin, motor runs, but will not spin
Posted on May 15, 2009
  • 113 Answers
Take the screws and brackets holding the motor and pump, pull it to the side and you can see where to replace the drive link
Posted on Apr 24, 2009
Remove drive from Arcdisk 20
If the power plug on the drive doesn't work, putting it into an external case is pointless.
Dec 30, 2013 | Archos ARCDisk 20GB 4200rpm 480Mbps USB...
External case is broken from falling and usb port is no longer fixed in place which I discovered afer removing outer shell. Can it be repaired or can I purchase a new caseand where would I find one ? No...
You can purchase an external case from many websites and local retailers. Depending on the drive, 3.5" or 2.5", you can purchase an enclsoure kit to use this drive in. By fully disassembling the broken case from the original drive, you can simply insert the drive into a new enclosure and use the drive as you did before.
Apr 17, 2011 | Seagate Computers & Internet
2002 Chevy SC1 1500. 64,000 miles. Went to put in reverse, engine made a clunk sound and then whined. Now reverse will not work but just whines when put in that gear. Drive works normally. Any ideas?
Are you sure you have all the forward gears?(4speeds ,three shifts)This is a common problem with this transmission and it is almost always a broken reaction shell.The shell brakes due to a diagnostic code setting and putting the trans into a high pressure setting and braking the shell.It is possible that you have a problem n the reverse input clutches but this is rare.Eithe rway the transmission will need to be removed and diasssembled.Good luck and let me know if I can help.
Apr 05, 2011 | Chevrolet 1500 Cars & Trucks
My kenmore clothes washer is grinding on the spin cycle. It is not the coupling because I just changed that. I am thinking that it has something to do with the gearcase. It almost sounds like a shaft...
THE SPIN BASKET ON YOUR MACHINE SITS ON A PART CALL THE DRIVE BLOCK. THIS CAN BE BROKEN.
YOU WILL HAVE TO REMOVE THE AGITATOR. UNDER THAT YOU WILL SEE A BIG NUT WHICH IS TIGHTENED ONTO THE "DRIVE BLOCK. LOOK CLOSELY NEAR THE CENTER OF IT AND YOU WILL TWO EARS THAT COME UP SLIGHTLY TO JOIN THE DRIVE BLOCK. THE EARS COULD BE NOT CONTACTING PROPERLY AND ALLOWING IT TO SLIP. THIS CAN SOUND LIKE A MACHINE GUN SOMETIMES.
OR, THE DRIVE BLOCK IS JUST BROKEN AND ALOWED THE SPIN TUB TO SLIP DOWN AND NOW ITS RUBBING AGAINST THE OUTER SHELL.
PART NUMBER - 389140
BUY IT HERE- http://lartoday.com/order_parts.htm
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Kenmore Washing Machines
Disk stuck in j drive, no pin hole
GO TO DEVICE MANAGER AND SEE IF THE DRIVE IS WORKING.IT MOST LIKELY IS SO TURN POWER OF PC OPEN THE SHELL ON PROSESSER AND TAKE DISC OUT,KNOW BEFORE YOU PUT SHELL BACK ON TURN POWER BACK ON DO NOT TOUCH ANYTHING EXCEPT THE DRIVE SEE IF IT OPENS OR CLOSES.IF IT DOES NOT,SHUT POWER OFF AND UNPLUG DRIVE THEN PLUG IT BACK IN.PUT SHELL BACK ON AND SEE IF DRIVE OPENS.IF NOT THE DRIVES FAULTY...HOPE THIS HELPS
Nov 30, 2009 | E-Machines emachines (emachinees) CD-ROM...
I dropped my hard drive. It powers up, and spins.
Hello, Fortunately the WD shell your HDD is in is rather delicate. So, there is a good chance the damage from the drop is limited to the shell. Take the drive to your local computer store and have the techs transfer the drive to a new shell. If it works in the new shell you're done. If it doesn't get back to me with your location (Region and City) and I will give you a recommendation for an appropriate data recovery lab. Chris
Jun 04, 2009 | Western Digital My Book Essential Edition...
Hard Drive not powering on
kschamu here is the only fix for you you need to go out to best buy and get a external hard drive shell and go into your external and remove the disc and put in in the new shell
Sep 03, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Direct-Disc Labelling
It depends on what kind of labeling you would like to achieve.
If it's lightscribe, then you could either purchase an external drive to achieve this and connect it through USB.
Or there are Lightscribe drives for laptops now that you could remove your current drive, and mount the surround from that to the new internal drive.
Thses days laptop DVD drives are fairly standard and are changed between laptops with the addition of the outer plastic shell that just unscrews.
The shell will also include the adaptor to go between the laptop drive and the laptop itself (much like a laptop hard drive)
Apr 08, 2008 | Dell Inspiron 6400 Notebook
Roper RAX4233PQ Top Load Washer Logo
149 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
