Question about Technics SL-1210 Turntable
RCA Phono plugs
When the playback is going on, the sound can get blurring, fuzzy, now it can get worse or better when I touch the rca cables. If its a problem with the RCAs - then what is the solution, and how easy is it to fix it.
    Novelist:
    Champion:
  • 382 Answers
Replace the rca leads, make sure the ground lead is tethered, make sure the lines arent crossed under the headshell....but soldering a fresh pair of rca, usually fixes that....Also remove the headshell/cartridge, and see if there is any residue in the 4 contacts in the tonearm....
Posted on Oct 28, 2007
Looking for manual for pioneer sw200 powered subwoofer
Most subwoofer have a left and right phono/RCA sockets. The amp should have a sub out phono/RCA plug. The sub should have come with a phono/RCA lead that will connect these - one plug to two plugs.
Apart from the mains plug that's all there is really. You may have to switch the sub socket on the amp on.
Or you can get one of the cables from places like below:
http://www.custom-cable.co.uk/hifi-cables/subwoofer-cables/
Sep 13, 2014 | Pioneer Audio Players & Recorders
Crosley turntable won't play through home stereo
Quite possibly the sockets you put the deck is not designed for the playback of phono signals. They should be marked "phono".
Other issues are earth connections.
Mar 17, 2013 | Audio Players & Recorders
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
May 27, 2012 | Audio Players & Recorders
I want to plug in my iPod touch to the DVD player I have, it's an SA-HT930 DVD home theatre sound system. But I don't know how :( can you help me out? I need some pretty easy to follow instruction...
The manual...
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
May 29, 2011 | Panasonic sa-ht930 Home Theater Audio...
Hi i have just bought a alpine dvd headunit the 105r and it only has 1 phono sub output and not the left and right phono output how do i connect my amp to this
it has 3 pairs of rca outputs, one pair for the front, one for the rear, and another for the subwoofer. the other sub preamp output is not needed to run to your amplifier.
For better sound quality, buy an RCA Y splitter cable (single male connection to double female connections), and run your regular pair of rca cables to the amp.
Nov 03, 2010 | Alpine Car Audio & Video
Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
May 09, 2010 | Stanton T.120 Turntable
Distorted recording and loud
If you're using the RCA cables, how is the switch set on the TT?
From the manual....
2. RCA Audio Output Cables: These cables should be plugged into a CD or Auxiliary input on your computer. IMPORTANT:
There is a switch on the bottom panel, next to the RCA cables that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input.
Mar 29, 2010 | ION Audio iTTUSB Turntable
Record/playback
Run audio INTO the MD play in the L & R IN jacks.
For playback, run (RCA phono plug cables) from the L & R OUT to your amplifier AUX or TAPE inputs. Try playback working first, then add the record function.
Mar 26, 2009 | Audio Players & Recorders
Ipod input for sa-eh760
You can plug the Ipod into the mic input , to do test recording. But the result wont be great.
To listen the Ipod in your stereo you should plug the Ipod into the Auxiliary input on the stereo.
Naturally you do not need any dvd.
Here is the adapter: 1.5M 3.5mm Male to Male AV Audio RCA Y Adapter
Feb 17, 2009 | Technics SCEH790 CD Shelf System
Video Connections
These are all the connectors on the back. The "1 x component video output" indicates that you can use the "3 color video cord" you have, better known as Component Video Cable.
Connector Type: 1 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video output ( RCA phono x 3 ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear ¦ 1 x digital audio output (coaxial) ( RCA phono ) - rear ¦ 1 x digital audio output (optical) ( TOSLINK ) - rear ¦ 1 x network ( RJ-45 ) - rear ¦ 2 x USB - front
May 16, 2008 | Toshiba HD-D1 DVD Player
Technics SL-1210 Turntable Logo
218 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
