I want to lift the top cover on top loader - Washing Machines
  • 113 Answers
Some have tabs you can use a flat head screwdriver to pop the top up. some have to screws at the bottom front you take out take the front off first and then you can raise the lid
Posted on Apr 24, 2009
How do you take off the front panel/cover
need to know what washer you have, make and model, but generally take off top, or release front of top and lift it up and back, then remove control panel if front loader, and then remove front.
Sep 08, 2015 | Dryers
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a xerox 8200 with a faulty printhead and I'm attempting to replace it, the instructions say to remove the top cover but not more. How do I remove the top cover? I figured out how to remove the side...
Weird directions. You to have to remove the side covers. The top cover is the ink loader. The tray where you install your ink sticks. You need a thin flat blade screw driver to remove it. There are no screws just some tabs on the sides that you have to release and it lifts out. Pretty easy. There are 1 or 2 plugs to disconnect on the ink loader. Then remove the print block. and the 2 spring clips on the sides of the print head. It really is an easy replacement. But DO NOT under any circumstances touch the jets , the front plate of the print head.
There are no screws to take out the ink loader once you have the side covers off.
Feb 15, 2010 | Xerox Phaser 8400 Laser Printer
When , I scan using the top loader, a red line appears
I would say to clean the glass where the scanner bulb is parked. Just lift up the cover and clean the glass. if you look close you could see a red mark on the glass. Steven
Feb 04, 2010 | HP LaserJet CM1312 All-In-One Printer
Need to replace the power supply on a Xerox Phaser 8200 and don't know how to remove the side and top panels
To remove the sides, there is one torx screw on the upper side on the rear of both covers ,and one torx screw inside the front upper paper path. You open the paper path door, as if you were removing a jam, then you will see the screws on the upper top of the cover.
Remove those screws and then go to the side of the machine and pull up and out of the covers to release the tabs.
The top, I am not sure you have to remove, but where you load the ink. there are just some tabs that hold the ink loader in, You use a thin blade screwdriver to release those tabs and then lift the ink loader out. There are 2 connectors to the ink loader to unplug.
Dec 29, 2009 | Xerox Phaser 8200 Laser Printer
Water runs out under machane onley when it agitate. How do i take off front panel?
Is this a top loader, if it is, there is a gasket under the top cover sealing the tub. lift up the top and replace the gasket.
Nov 26, 2009 | Magic Chef Washing Machines
How do you remove the top on a LG WM2077CW front loader?
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
Nov 09, 2009 | LG WM-2277HW Front Load Washer
Replace rubber gasket
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Jun 21, 2008 | Washing Machines
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
