Flexisign 8.1 printing shape borders - Computers & Internet
Bottom of borders missing
Check to see if your paper setting is A4 instead of 8 1/2 x 11. If so change it.
Jul 04, 2010 | Dell 924 All-in-One InkJet Printer
HPz6100 rips but doesn't print
Try going into the Web interface by typing the ip address in internet explorer instead of an web address. Go to the setup tab and on the left is a date/time link. Go in there and change the date on the plotter to before the expiration date to see if that takes away the message. Hope this helps.
Nov 10, 2009 | HP Designjet Z6100 InkJet Printer
Crop the photo in diffeent shaps like heart.
The crop tool will not let you crop in shapes like elements cookie cutter tool will. However, there is a work around to do what you want to do which indecently is the same as you would have to do in Photoshop CS4.
1. Create a new document file or press Ctrl + N.
2. Open an image you want to crop.
3. Press Ctrl + A then Ctrl + C to copy the image.
4. Select the new document file you created and press Ctrl + V to paste the new image in a new layer.
5. Select the Rectangle tool or press U for the hotkey.
6. Move the mouse over to the Rectangle Tool and hold down the left mouse button and select Custom Shape Tool.
7. At the top of the menu you will see a Shape: icon with a pull down option. Left Click on the arrow to expand the window to select the shape you want. If you want more shapes to choose from when the shape window is displayed click on the arrowhead with a circle around it and select a new library or all.
8. Use the mouse to draw the shape to the size and location you desire.
9. The shape will be in a new layer with a mask which will cover the image. Hold down the Ctrl key and left click on the Shape 1 layer in the layer window. This will mask the shape and only the shape.
10. Press Ctrl +Shift + I to invert the mask selection.
11. Use the Select pull down menu to Feather, Modify, Contract, Expand and Border if you want apply those effects around the edge of the mask.
12. In the Layer window click on the eye next to the Shape 1 layer to hide the image.
13. Select the image layer you want to crop and press delete which will delete everything outside the custom shape you created.
14. Do not forget you can right click on the image layer and select Blending Option to add drop shadows and other special effects for the cropped shape.
Jun 05, 2009 | Adobe Photoshop 7.0 for PC
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
No bottom page border
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Flexisign pro 7 help:
best way is to use the beizer tool, image, vectorize beizer. if more clean up is needed use the path edit tools.... r click in a blank area of the tool bar and put a check mark in the path edit bos to turn it on....
Sep 03, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
