Question about Acer AL1717-BBMD 17" LCD Flat Panel Monitor with Speakers (Black)
Built in speakers do not work
I have connected the power and vga cable, the monitor works fine but the built in speakers do not work.
how can i make them work?
  • 123 Answers
Have you connected them to the pc's sound card - it doesnt go through the video cable.
Posted on Apr 24, 2009
Hp 1740
You might need to replace the sound card or download the audio drivers for your motherboards audio.
Apr 16, 2014 | HP Audio Players & Recorders
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Why wont the sound work when u use the computer monitor plug ?
Hello,Unfortunately, unlike HDMI, VGA and DVI cables do not carry audio signals. If the monitor has built -in speakers, you will need to connect a audio mini jack from the computer to the input on the monitor.
Nov 17, 2011 | Televison & Video
I think ihave a audio on my monitor,so shoud it work
I see that you believe that you monitor has a built in speaker on it, if your monitor does have built in speakers on it then the only way to make the speaker get audio from the monitor is to have it hooked up on your computer using an HDMI cable connecting your monitor to the computer where audio and video will be rendered by the HDMI port providing Video and Audio to your monitor.
But if your monitor does not have HDMI on it or you computer does not have an HDMI port then that will be an issue, if your computer does not have an HDMI port then getting an expansion Video card that has one will make thing work for you and get you audio out of your monitor.
If you are only using VGA or a DVI cable connecting your computer to the monitor then audio will not come out as it should on the monitor.
I hope this will be informational and helpful to your concern.
have a nice day,
mvincentc
Oct 26, 2011 | Proview PL926WBi 19" LCD Monitor
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
Do you offer any help about a monitor that goes black and says "no input" or something to that effect....?
You must properly connect that VGA cable from monitor to built-in VGA serial port of the motherboard or connect it to the Graphics card in your cpu unit if you are using a graphics card and not the built-in VGA serial of the motherboard. Then lock it.
Dec 31, 2008 | Audio Players & Recorders
RELISYS MONITOR How do I get the speakers to work please ?
Hey...Dude,
To check if there a built-in speakers... look under the monitor and look for a audio jack usually located next to the VGA and power connections. If you got one, then you need a audio cable to connected to from your monitor to your pc audio output jack.
Nov 21, 2008 | Computers & Internet
No sound from built in speakers
the built in speakers on the monitor are only speakers, they are not run through the video signal cable and have to be connected separately.
many monitors with speakers provide a stereo cable in the package but dont tell what the cable is for.
If there is a cable provided there will be a small jack on the monitor that connects to audio out on the sound card.
There may also be a stereo plug combined with the video cable, that likewise connects to audio out.
If the hardware is connected, there may be a volume control on the monitor that may be muted.
If the problem is a recent thing for a system that previously had working sound with this monitor, try the mute on the audio settings
Jul 12, 2008 | HP vs15 15"LCD Flat Panel Monitor
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
416 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
