Question about Garden
Tension spring placement on deck of dynamark 12.0/39
2 Suggested Answers
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
Manuals on deck assembly dynamark 12hp/39 model d3912190
For an assembly diagram, contact Dynamark directly.
May 06, 2017 | Garden
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Mar 07, 2016 | John Deere Garden
Need diagram of deck belt placement on dynamark 12.0 39 lawn tractor
If the belt seems to be working then comes off once in a while then the guides that hold the belt in place may be bent out too far or not put on right.If it just jumps off when you go to start up then you have other issues. Could be your pulleys are not lined up. My feeling its your guides are not working properly.
Nov 02, 2014 | Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
How do i adjust tension on drive belts
Hi there, If you lower the deck to its lowest level and follow the track of the deck belt you'll see the tensioner pulley. Check its spring is still engaged and strong enough, some mowers let you hook the spring into different holes for more/less tension. Check the pivot bush isn't too slogged out for it to tension properly.
May 24, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Diagram of deck belt placement on John deere lx 277
Hi Vicki,
1. The yellow arm sticking up that has two notches in it is supposed to have a spring attached to it. That is what causes the tension. It doesn't look like a spring is attached in the video.
try this link-it will take you to the owners manual and a picture of the belt routing. copy and paste the link into your browser
https://groundscare.custhelp.com/ci/fattach/get/51655/0/session/L2F2LzEvdGltZS8xMzUwNjkwNjczL3NpZC9jbm10RTg5bA==/filename/275+-+LX266+LX277+LX277AWS+LX279+LX288.pdf
Oct 18, 2012 | Garden
Need diagram for a dynamark lawn tractor
Need a diagram for a dynamark mowing deck
Jul 15, 2012 | Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach?...
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
May 18, 2011 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
