Question about IBM Infoprint 1120 Laser Printer
Have to replace controller board / engine board
I have to do a repair on an IBM 1120 and need instructions, preferably with pictures for replacing the controller and engine boards with an estimated time from start to finish for a first timer.Where can I find this information?
  • 26 Answers
Controller board and engine board are on the left hand side of the printer. remove side cover (plastic) and screws to silver cover. controller bd is first - just a bunch of screws and one in the back where the eithernet plug area. (some you dont have to remove but mostly remove the big ones - it will come free. Keep track of which screws go where. The engine board is next. All the plugs are either size or color coded you cant mix them up. a few more screws and the engine bd is out. Reverse to install.
Posted on Feb 04, 2009
How to change samsung tv t con board
Ken, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
LCD TV Repair
Troubleshooting Distorted Video Con of LCD Panel TV Repair Vizio Sony...
Mar 22, 2016 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
Need print driver for ibm 1120 using win 7 64 bit
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
Dec 12, 2012 | IBM Infoprint 1120 Laser Printer
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
Hi, my tv screen just went off. When i switch it on it shows a picture then becomes black on screen, please advise
Your backlight controller board is faulty and requires repair. It may be due to bad capacitors or a faulty inverter transformer. Capacitors are fairly easy to replace, the inverter transformer is harder to replace and it is often easier to replace the whole controller board. This type of repair should only be carried out by an experienced electronics engineer.
Mar 15, 2011 | Televison & Video
Need driver software for Printer Installation, where can I find?
you can download a copy for your IBM infoprint 1120 laser printer from here
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Jan 27, 2010 | IBM Infoprint 1120 Laser Printer
Paper tray is in the printer,but the printer says missing tray 1
There are two possible solutions: The first is that the lugs on the side of the paper tray are broken, and the printer cannot "see" a paper tray. In this case you need a new paper tray. The other possibility is that the tray and paper size sensor inside the printer is faulty. Often just pushing the contacts can free them, and sometimes the metal prongs that sense the lugs on the side of the paper tray get unseated. Just use your finger to reseat them correctly. If that doesn't work, the sensor board is likely to have failed, and will need replacing
Jun 11, 2009 | IBM Infoprint 1120 Laser Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Lexmark T520 wont work!
To start do the following:
Unplug printer USB, unplug power from pc and also remove the battery if it is a laptop, and restart printer and PC.
With printer still unplugged go to control panel>>printers and empty the printer cue.
Test a replacement USB cable and try plugging the printer on a different USB port.
If the above did not work , then reinstall the printer software using the printer CD. Unplug the printer and start software installation with printer USB unplugged.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Mar 06, 2009 | IBM Infoprint 1120 Laser Printer
IBM INFOPRINT 1120 Invalid Engine COde
Invalid engine code --- is a bad engine board - located on the LHS of the printer behind the formatter board
Nov 04, 2008 | IBM Infoprint 1120 Laser Printer
P17 Security Violation
This is not a good sign. Have you recently replaced the controller board ? Or upgraded the microcode. This error refers to the Security Pal chip on the controller board. Itt would be worthwhile reseating it , if you are compitent to do so. Otherwise you may be lokking at calling an IBM engineer to solve the problem.
Where are you located ?
Aido
Jan 21, 2008 | IBM 6400 Model i10 Matrix Printer
IBM Infoprint 1120 Laser Printer Logo
144 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
quennie732
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
