Question about Troy-Bilt 25cc 4-Cycle Heavy Duty Gas Blower TB4HB EC
I have a troybilt leaf blower TB4Hb ec used very little, blows oil out carb
2 Suggested Answers
SOURCE: what is the gas/oil mixture
40:1
Posted on Jul 09, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troybilt blower wont run full trotlle
Could be several things, check the air filter, carb might need cleaning or adjustments, could be bad gas, dirty spark plug, worn engine. lots of possibilities, too many to list.
May 25, 2014 | Garden
Yardman 27cc 445cfm Backpack Blower starts fine, but when I try to depress the trigger for more power it dies. Idles smooth with full choke and dies when on no choke setting. Have had someone say it needs...
There may be a plugged fuel filter in the fuel tank, or perhaps you have the oil mix to rich. other problems could be that it needs a new spark plug or carburetor adjusted.
Try spraying the carb out with carb cleaner, add a little seafoam in with the gas.
Oct 21, 2013 | Mtd Products TB2BP EC 27Cc Backpack Blower
Engine will not go to high speed fuel oil mist blows out .checked spark arrestor ,muffler,exaust ports.
If the mix is blowing out the muffler than it is flooded either due to improperly adjusted carb, stiff diaghrams in the carb or weak spark. Weak spark could be a bad plug, failing ignition module, or spark ouit of time ( sheared flywheel key).
Bad fuel will also cause this symptom.
Oct 25, 2012 | Troy Bilt Tb320bv Spring Assist Blower/Vac
My troy-bilt blower/vac is blowing oil out of the carb. what are some things that may cause this? Oil level? How do I know I have proper amount of oil? If I leave the foam filter and the carb cover on, the...
Your oil breather (on the side of the engine opposite the carb) may be malfunctioning/defective allowing the carb to **** oil from it. There is a breather tube that crosses over the top of the cylinder connecting the crankcase( oil) breather to the air filter housing. Check the oil level and the condition of the air filter and esp. the oil breather. It serves the same function as a PCV on a car engine.
Aug 09, 2010 | Troy Garden
Troybilt 6.5 briggs won't start floods gas
if it sat more than 3 months with out being started it needs a carb clean this can be done in an hour if your at all mechanically incline
1. remove carb and take it apart
2. buy a can of carb cleaner
3. spray carb cleaner in every hole ypu can find
4. becareful around rubber with carb cleaner it will swell it up
5. put carb together and reinstall
if the inside of carb is real bad get a rebuild kit and replace the parts
Apr 13, 2009 | Garden
Troy-Bilt 25cc 4-Cycle Heavy Duty Gas Blower TB4HB EC Logo
67 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
