Cs 1000 running cs 1000 through two peavey DTH 2 cabinets..the other day the amp volume went very low and the DDT light are flashing on and off have it in stereo mode and both channels are doing the same thing what could have happened?
  • Anonymous Jul 28, 2008
    Hi. I have a peavey cs1000 and the problem it's like stevepht's problem. With a very low input signal the DDT led's flash...
  • 682 Answers
Try the following:- go to (radio shack) near to you and obtain a good brand contact cleaner and apply spray over volume control while you are moving it forward and backward.-also try to unplug it from walloutlet and reinsert it again.-also confirm the cabels to speaker in good condition and no short circuit in it and nothing touch eash other.
Posted on Apr 25, 2008
SOURCE:
My peavy has three lights at power on when in use red light comes on is that beacuse my amp is overheating or is it normal it does that when i crank the volume amp i not hot well vented
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00512180.pdf Page8 sections 2 through 4 discusses the LEDs. I think what you arte talking about is the DDT active LEDs. Page 12 specifically discusses this and page 15 notes that Red signifies DDT clipping. Peavey recommends that you don't defeat the DDT circuit and that is good advice as it protects your amp and your speakers. The clipping is not caused by the amp but by the amount and quality of signal being input. Check earlier in your signal chain for the cause.
Aug 14, 2010 | Peavey Pv 2600 Power Amplifier
Peavey PV 8.5C DDT is activated on channel A even al low volume, channel B works fine. All 8 power transistors on both channels were found OK. Driver transistors and 15V zener diodes are all OK as well....
Check your speakers and Cables. I had some speakers that traveled in my small trailer and the vibrations of the trailer caused the diaphram to back off my horns. Once I got the speakers fixed the DDT light on my power amp stopped staying on so much.
Jan 07, 2010 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
What is DDT my system cuts out when DDT lights up
Go to http://peavey.com/support/searchmanuals/archived.cfm Their main site also has info. DDT is an active compression feature to protect the product .
Jul 04, 2009 | Peavey Pv 2600 Power Amplifier
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Wiring my peavey 112xt subs with my peavey 2xt tops
hi don't know if you have sorted this yet, you need to wire your cables that go from sub to top +2 -2 on the speakon (on the sub end only) HTH
Jan 04, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Need the instructions for a peavey 158 Rage amp
Here is the link to the Peavey 258 Rage. The difference is the 158 is 15w and the 258 is 25w.
http://www.peavey.com/assets/literature/manuals/00583600_4.pdf
Dec 27, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Guitar amp
You can order parts directly from Peavey. You'll have to call to place the order. You can use the followng email address to check price and availability.
[email protected]
For more information, the third question/answer in the list of FAQs has the phone numbers.
http://www.peavey.com/support/faq/index.cfm
Oct 14, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
376 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
