Question about Gaggenau Vg 223=812
Change gas orifice from LP to natural gas - Gaggenau Vg 223=812
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
Mod jgp328wec2ww changed orifices from nat to lp. Burners not getting hot enough. It took 12 min to bring 1 qt to boiling and not rooling. how is this adjusted?
Please tell us everything you did to convert your stovetop/oven to LP? Beside swapping the natural gas orifices for LP orifices, did you also switch the appliance regulator over to LP? When you put in the orifices did you match up the proper size ones to each different size burner according to your owner's manual? They have #'s stamped on them to identify them and some are even color coded. Were you having any similar issues with your previous stove? If so, it may be a pressure problem. I can help you solve this problem with a little more information. Douglas
Oct 05, 2010 | GE Cooktops
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
Natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Convert to LP?
If it is possible, then the orifice has to be changed. The regulator may need to be changed as well. I am a certified LP technician for recreational vehicles, but I don't know enough about this particular appliance to say for sure if it can be converted. The best thing is to contact Miele directly, but this sort of conversion always requires a different orifice. Note that propane, butane, and natural gas are all forms of LP (Liquified petroleum), so conversion between the 3 is usually possible
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Convert to LP (propane)
Contact Miele directly via their website. This would require an orifice change if it is possible for this appliance. Since natural gas, butane, and propane are all forms of LP (Liquified Petroleum), it is usually, but not always, possible.
Gaggenau Vg 223=812 Logo
27 people viewed this question
Top Gaggenau Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
