Question about Canon NP 6551 Black and White Copier
Error code E522. How to fix this?
NP6551 canon copier has a error code- E522. It says to turn off and on the copier again. Done this several times. Error still occurs when I try to copy something.
I got this problem fixed by removing sorter unit and it works. Because Error code E522 is an error with the sorter pushing bar/motor. If this was an emergency, then it fine to do. Just turn off power power switch and detach sorter unit with unplug power cable of sorter from main unit.
But the problems was that you won't have paper tray to for your copied papers and you have to pull each paper out by hand, fastly before it said "paper jam".
Posted on Jul 30, 2010
    Scholar:
  • 93 Answers
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Posted on Apr 24, 2009
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Error Code: E631 & E632 on Canon NP6551
make sure the error code you gave to us is E631 & E632 notE531 & E532, you number not on our menu, if my number is correct that's mean stapler motor defect, replace it!
Oct 03, 2008 | Canon NP 6551 Black and White Copier
Error message E0532
E532 The stapler does not return to the home position for the front/rear shift operation within a specific time.
Problem with stapler unit or stapler board
Sep 25, 2008 | Canon NP 6545 Copier
Image runner 3300 error code
it is a fuser film unit problem,thermistor is a poor contact (or) fixing heater is a problem.
do the following
press additionel function* button at once & press 2&8 buttons at a time and again press additonel function* button.
select COPIER>FUNCTION>CLEAR>ERROR>OK.
turn off the machine & on its again.
all the best.
Aug 09, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Np6545- erroe code e522
Hello Good Day amazingfirst! you problem for Canon NP-6545 error code E522 according to my Service Manual the problem is the Sorter push bar motor. try to check the sorter motor, add grease if needed so. just focus on the sorter motor ok! there is no need to reset the error code just on and off the machine and it will automatic reset the error code but make sure that the sorter motor will works ok!
Christopher
Jul 15, 2008 | Canon NP 6545 Copier
Please help
E401 RDF Pickup motor or pickup sensor problem, try to clean the sensor and reset the error code in *4* ERROR clear.
Jul 08, 2008 | Canon NP 6551 Black and White Copier
Error code: E002 at canon NP6551
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Jun 02, 2008 | Canon NP 6551 Black and White Copier
E210
Error 210 means that the printer scanner hasn't returned in its initial position.
You should see there http://en.allexperts.com/q/Repairing-Copiers-Faxes-1748/Danka-Copier-Canon-NP6551.htm , it may help you.
Feb 05, 2008 | Canon NP 6551 Black and White Copier
Error code e000014-0000
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Nov 02, 2007 | Canon imageRUNNER 5020 Copier
Canon NP 6551 Black and White Copier Logo
222 people viewed this question
old marine
old marine
