Question about Nokia Asha 311 Mobile Phone - Unlocked Red
Debugging mode - Nokia Asha 311 Mobile Phone - Unlocked Red
HOW do I get to debug mode on Samsung note 10.1 2014 edition p 605?
go to About phone then press the Build number 5 times, like that the devlopper option will be activeted than go back & entre it and enable USB debuge
Sep 13, 2014 | Samsung Galaxy Note 10.1"
How can i enable usb debugging for pioneer r1?
Generally, to enable hidden developer features in Android (like usb debugging):
Go to Menu-Settings-About device
Tap on "Build number" multiple times. You should start to see a message that says something like "Tap 3 more times to enable developer mode" and so on until it says Developer mode enabled. You should then have a Developer options selection available in your menu that includes a USB debugging option.
May 11, 2014 | Generic 4"" x 3"" digipro wp4030 usb...
Resetting bios password on viewsonic viewtab 10pi
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt
Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter.
Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
Youll notice the password is gone.
If this fails try typing
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html
At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Nov 05, 2013 | Computers & Internet
Need know bios password
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
o 70 2e
o 71 ff
and hit Enter. Finally type:
Quit
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Feb 10, 2013 | Computers & Internet
Microsoft visula c ++ runtime error how to fix it
I assume here that you are writing an app in VC++. If the problem is that the code runs in Debug mode, but crashes in Release mode, the usual reason is a pointer overflow bug. This is commonly when a pointer is not initialized or a buffer is too small for the data written to it.
In Debug mode all variables are surrounded by guard bytes (allowing the app to run...), but these are removed in Release mode. The guard bytes are the main reason that Debug builds are about 2x the size of a Release build.
Set Debug mode, and hit F5 to run the app. It will probably stop at the source of the error. If not, then you'll need to put in some MessageBoxes in various places to locate the code region that has the bug.
sd www.pixcl.com
Jun 09, 2011 | Microsoft Computers & Internet
I don't know where to put in cheat codes for second life
There are no real cheats for Second Life. A game such as that would never allow for any major cheats, especially money cheats. Now you can enter a debug mode for simple options that are like minor cheats for your own personal fun.
Press Ctrl-Alt-D while in-game to open debug options. Here you can control various things such as turning on wireframe mode, or making invisible objects visible. Note any change you make will have no effect on other players. To disable debug, press Ctrl-Alt-D again
May 19, 2011 | Computers & Internet
Problem in Visual Basic 6.0 application
You need to run your program in debug mode and step through the code one line at a time. Have a look at the values in your variables and see if they mach what you expect.
This is one of the skills of a programmer. When things don't go as expected you need to be able to figure out what went wrong.
If you don't have or can't use a debugger you can create a debug mode in your program perhaps with a command line variable or a value in a config file. When debug mode is turned on your program will output lots of information to a log file with details of module names and variable values. This is also useful if later on a user is having problems you can instruct them to turn on debug mode and send you the output.
Hope this helps.
Aug 24, 2009 | Microsoft Visual Basic 6.0 for PC
Nokia Asha 311 Mobile Phone - Unlocked Red Logo
21 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
