Question about Sony XPLOD CDX-GT200 CD Player
XPLODE I'm getting no sound out of my car stereo with a cd in but it plays fine with the radio.
  • tex1 Mar 18, 2008
    the wires are ok but the problem continues
Yeah i just found this site and thank god, i was having the same problem even took back a cd player and got another one. lol....but, I just flipped flopped the blue/white with the blue and same with the other. walla. thanks tom!
Posted on Sep 14, 2008
I had the Same problem with my new Xplod BT2600,
radio played fine, but no CD sound, even though it found and successfully read disk. Followed tom tom 5's advice, that did the
trick.
Thank you so much.
Greatfull in Pittsburgh Pa.
Posted on Jul 07, 2008
  • 78 Answers
It sounds like you have an externally amplified system and the amplifier remote switching wire is connected to the electric aerial output which is a blue wire and it should be connected to the amp remote wire which is a blue with a white trace
Posted on Dec 19, 2007
New Alpine radio, went through setup, plays fine on radio/tuner on all four speakers, but ipod (USB port) or internal CD only plays on front speakers.
Just a thought - the usb provides a digital signal which carries information about how the signal is to be processed; mono, stereo, surround sound stereo, etc.
If the mp3 music file was only recorded in 2 speaker stereo perhaps that is how it plays back.
Admittedly the radio signal is stereo and yet it plays on four speakers but unless it is a DAB radio it is analogue and maybe that makes a difference.
Perhaps there is an internal electronic fault with the digital processing part of the unit. I suggest reading the handbook again and then perhaps contacting the seller.
Mar 28, 2016 | Alpine Car Audio & Video
Installed a Sony Xplode into a 99 Blazer and everything on the radio works but will not play through the speakers
The Bose system is complex - it has an amplifier separate from the Bose compatible radio. This amplifier takes low level audio signals from the radio, not full driver outputs from a replacement radio, and by trying to use the replacement radio you may have blown the amplifier. If that is the case, you may not be able to go back to the original radio.
The only option you may have with the replacement will be to find the Bose amplifier and bypass the connections to feed the replacement radio outputs directly to the speakers. This may not be as simple as it sounds, as distribution to the various speakers comes from the amplifier, not the radio, and the wiring from the amplifier to the radio may not have all the wires you need. Before going on, you had better get a wiring diagram for the Bose system (service manual or Alldatadiy.com).
Jun 11, 2017 | 1999 Chevrolet Blazer
Have mex bt2600 sony xplode car cd player ::: also have sony xplode amp model no.xm 754sx problem is i want to hook up a subwoofer and the amp to the head unit (also currently have 2 sony xplode 3ways...
If the Sony front end unit (stereo) has RCA jacks (Left and Right) in the back it's an input to the Xplode amp. If that's right then the Subwoofer putputs should plug or wire into the Xplode amp. I haven't hooked these up for some time but try a search on Youtube with the units you describe I'm more than 90% sure that there are videos there.
Nov 19, 2017 | Sony MEX-BT2600 Car CD/ MP3 Player
I have a 2001 ford escort and a sony xplode head unit and need a wireing diagram
just get wire adaptor and you radio will install in minutes. you get adaptors at walmart or any stereo shops.. save time and aggravation
Sep 16, 2009 | Car Audio & Video
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
RADIO PROBLEM
you should be able to get a factory connector for the unit that matches the stereo to the vehicle internal wiring. you will have to go to the dealer for this but you should not have to get a new head unit. please rate this solution....thanks
Aug 30, 2008 | 1994 Eagle Vision
Sony XPLOD CDX-GT200 CD Player Logo
203 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
