Question about Creative Labs Inspire T2900 Computer Speakers
Mic not working with sound pod for T2900
I plug in mic and all i get is static...headphone plug works good what kinds of mic's are compatable...i used an olympus (electret condenser michrophone me 4 & me 9) yes electret is proper spelling. they are origanaly for my mini tape recorder...are they not compatable with pc devices....do i have to plug those into back of pc for them to work. dont want to take chance on frying pc without asking first..ty brian
Yans, i have a trouble with the harman kardon audio driver for toshiba satellite m-305-s4820, would you like to send me the driver.
Posted on Apr 24, 2009
I got new Logitech Clearchat stereo headphones. I plugged the two pins into the pc - pink and green. When I do a skype test I hear the message from my computer speakers (settings says Realtek HD..with no...
realtech hd is your sound device. go into windows control panel and access the sound settings then navigate to voice settings click the volume button,your mic might be muted. also if you want the headphones to work plug them into the plug that your speakers are using (side-note: mics and head phones never need something installed to work as long as your sound device works and your definitely does work,only when the mic is a special interface like USB do you need to install software and/or drivers)
Apr 01, 2011 | Logitech ClearChat Stereo Headset Headset
Brand new ag30 when I plug my mic sm58 into it all I get is static no sound as in singing comes through it I'm using a XLR to quarter brand new lead.. Have tried everything when I hit the tip of mic sound...
You should be using XLR to XLR cable, NOT a 1/4 inch cable. There is a problem of the 1/4 inch being the unbalanced version and is not compatible with this unit's input.
Use the XLR to XLR mic cable and it will work fine.
The cable you have would work for one of those cheap Karaoke machines...
Mar 25, 2011 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
Hi, I have Commell LV-672 MB and I have weird sound problems, its buzzing and making weird sounds when I dont do anything (listen music or whatnot). same is when I use the mic, that weird sound is like...
Open up your computer the speakers plug/outlet is usually at the back of the computer as is the microphone input
to check the lead attached to the rear of the input plugs make sure the connections are good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Mar 21, 2011 | Intel Computers & Internet
When I plug my headphones into my iPod, there is no sound, unless I jiggle the cord around and do not plug them all the way in. They worked fine at the beginning, but do not work now.
I'm not certain it's not the I-Pod socket or the headphone jack that is playing up? If you can get another pair of headphones (a friends etc) and put them in the socket of the I-Pod, to test it that should clear it up. For if they don't work you know it's the I-Pod socket that's faulty.
If it's the Bose jack that's gone, you better see my tip on dodgy cable/plugs on headphones. You should be able to replace it with the 3.5mm type shown, but I think you can get the thinner type jacks.
Jul 09, 2010 | Bose in-ear headphones - Black with...
Losing sound when plug in mic
You are probably plugging the mic in the wrong port, you should plug it in the other port looks the same.
I think the port that you are plugging in your mic is of sound (headphones).
Hope this helps
Mar 30, 2010 | Audio Players & Recorders
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
My Logitech headphones mic won´t work with windows xp. Can hear, don´t hear me.
Your headphone mic is all right. The problem is with the sound driver you are using. Many a time the headphone jack are not properly connected so it may be another issue for not working of your headphone. Your operating system is all right check out the sound driver setting from the control panel.
Good Luck
Mar 02, 2009 | Logitech (980361-0403) Headphones
Computer wont recognize me Saitek GH20 Headset
I have the same problem. I suspect that this headset is not USB compatible at all. It possibly only uses the USB connection as a source of power (for the vibration effect). This is a problem for me because I wanted to use the headset on a PS3. Saitek don't claim that it works with the PS3, but the claim of USB compatibility is ambiguous and misleading in my opinion.
Feb 20, 2009 | Saitek GH50 Headset
Factory installed microphone isn't working anymoe
open up your volume toolbar, advanced and make sure that your mic is not muted, turned down or that your mic +20 boost is turned off. You can always uninstall sound drivers and have vista find them again on boot up, but Vista is such a new platform that your mic hardware may not be compatible. Good luck, I have never had good results with the windows mic.
Jan 24, 2008 | Acer Aspire 3680 Laptop
Creative Labs Inspire T2900 Computer Speakers Logo
234 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
