Question about HP Photosmart Premium C310a
Hp 310a paper feed rollers do not turn to feed paper.
adonscott
  • 106 Answers
SOURCE: Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
Posted on Jul 07, 2008
checkitright
  • 1362 Answers
SOURCE: HP fax 1020
try cleaning with alcohol if it doesn't work then yes it needs to be replaced
Posted on Aug 12, 2008
  • 28 Answers
SOURCE: hp 1210 paper will not feed
Hi ihimc1, over time dust and paper fibres can cause the rollers to stick, which can result in the paper not feeding please take these steps below to clean the rollers.
Turn off the all-in-one.Unplug the power cord from the back.Remove the rear access door. Clean the rollers one at a time using a clean cloth that is slightly dampened with water. Rotate the roller to clean the entire surface. Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
Reinstall the rear access door and then plug the power cord back in.Turn the all-in-one back on.
Posted on Nov 16, 2008
frcs68
  • 1605 Answers
SOURCE: Broken paper feed roller
you cn the roller from the link below:
http://www.precisionroller.com/manufacturers/hp-photosmart-c5280.html
Posted on Jan 27, 2009
Jay_Sav
  • 93 Answers
SOURCE: HP printer will not feed paper through the rollers
Pick up some Print Roller Cleaner spray, and carefully spray your rollers. As time goes on, fibres from the paper embed in the rollers, which reduce their efficiency to pickup and feed paper. Spray all the rollers and set it dry. You should find that your printer feeds paper. If not, you need a new roller set, available from the HP Spares, or a good local HP Dealer.
Posted on Mar 14, 2009
My HP printer is not feeding paper.
Here is the solution for your problem just go through the steps given below and you can fix it yourself.
1. Check to make sure your printer has paper in its paper tray. If your printer has paper, check to make sure that the tray is not overloaded. If you suspect your paper tray is overloaded, remove some paper from the tray and attempt to print again.
2. Use the same type of paper when stocking the tray with paper; do not mix different types of paper into a single stack. Mixing different brands and weights of paper in a single stack makes your printer more prone to paper feed problems. If you find that one particular type of paper causes consistent feed problems, switching to a different type or weight of paper may solve the problem.
3. Check to make sure the paper in the tray is whole. Torn and creased paper will cause problems with the printer.
4. Open your printer's rear access cover and inspect the paper feed rollers. Dusty or dirty rollers cannot grip the paper; clean them with a soft, damp cloth and water.
5. Count your printer's rollers. HP printers have six paper feed rollers; if your printer is missing rollers the paper will not feed correctly. Contact HP to replace the rollers and repair your printer.
Thanks.
Oct 06, 2010 | Computers & Internet
Feed roller rotates but paper does not move (feed).... I cleaned the roller
Hi!
Sometimes this can be caused by worn out tyres on the rollers. Like car tyres they wear out over time & become 'slippery' & fail to drag the paper the way they should.
Replacement tyres can be ordered from HP for your specific printer.
It may also be the cogs that turn the rollers, or perhaps the spring load on the paper tray (the part that raises the paper to the rollers). If it's either of those problems, I can only suggest taking it to a printer repair agent or if it's still under warranty, give HP customer support a call.
Hope this helps :)
Nov 21, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP 6310 - paper misfeeds and bunches up to one side when feeding into printer, causing paperjam. I tried cleaning the rollers, with poor results. Thanks for any help.
Please try these steps
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Mar 14, 2009 | HP DeskJet 5650 InkJet Printer
HP Laserjet 2200d -- Paper won't feed through
Remove the paper cassette and the toner. Turn the printer upside down and look at the feed roller.
It should NOT spin freely, drive tabs may be broken off of the roller shaft.
Jan 23, 2009 | HP LaserJet 2200dn Printer
Hp 1210 paper will not feed
Nov 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper Jam Error
Good luck...
Sep 04, 2008 | HP Photosmart 8750 InkJet Printer
HP Photosmart Premium C310a Logo
35 people viewed this question
Seeker5211
Seeker5211
