Hitachi 42PD97OOU screen appears to have had something spilt causing marking which seems to be getting worse, but we have never spilt anything down the screen. It appears to be on the reverse of the screen and is inaccessible. Have you any suggestions as the problem has got steadily worse over the last 18 months and makes viewing difficult when the sun is on the screen.Television is now approximately 6 years old and performs perfectly with this one exception. regards Garvin Parry
premtech
  • 934 Answers
SOURCE: hitachi 50vs69a
Spanking comes to mind... :) Just kidding..
You can access the inside area od the screen and with some windex and paper towel clean the reverse. There are actually two screens there sandwiched together, a lenticular and frensel screen. If you remove the front panel you should be able to remove the screens from the frame and clean between them also... If any of this makes you nervous calla qualified shop and they can do this in minutes on a house-call..
Have a great day!
Bill
Posted on Nov 21, 2007
ctf1800
  • 4402 Answers
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
SOURCE: Hitachi 51F59A Color/Dark problem
Could be the blue CRT shorting out. I had the same problem but with red. Eventually it shorted out completely. If it is only 2.5 month old it should still be under warranty and they will fix it.
Posted on Feb 27, 2008
  • 96 Answers
SOURCE: Pink Dot in center of screen.
Well, You have a bad engine, so what other's called lcd projector motor.
This will cost you, the engine states at about $500. I've seen this problem and right after I've change the engine for some
F#$% reson the bulb when, twice on me, that's another $400.
Good Luck
What About Bob
Timmins, Ontario
Home of Shania Twain
Posted on Mar 15, 2008
  • 927 Answers
SOURCE: LIGHT ENGINE FOR THE HITACHI 60V500
Good Day,
One the best ways to contact HIT is via the internet; hitachi corp. The light engine is very common problem for this product. Don't ask them to send part to you, work through a local Authorized Service Dealer. Ask them for a concession on the part. They only give concessions 50% of the time. My customers get the part about 98% of the time.(tech at house with estimate).
Good Luck, big IRISH.
Posted on Aug 19, 2008
Sticking keys Rt7D40
The most common cause of a problem like that is that some liquid has been spilt into the keyboard, and is now hardening through evaporation. Have you spilt anything, or does someone else use it as well?
If that is what's happened, I would replace it rather than trying to clean it out.
Sep 03, 2012 | Dell Wireless Keyboard Optical Mouse w0147
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
Screen keeps displaying menu options when that button is not being pressed on remote have to turn off tv to get back to regular viewing or game playing what is making this screen keep appearing
Hi. I suspect that the remote may be the cause. Remove batteries from the remote and see if the menu appears. If it dosent, I suspect the remote may have had something spilt over it and needs to be cleaned out. Hope this helps you out.
Feb 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
Hitachi 61SDX01B Dark Picture and bad color
There isn't anything you can do yourself for this problem, but it should be worth having a qualified technician look at it.
Sep 09, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Keyboard malfunction. when spacing ; appears. key c does not wor. goes to address bar. v is pressed the number 4 also appears
Hi, keyboard malfunctiopns can be caused by a few things. One of the major causes is liquid (the stickier the worse) being spilt into the board but if you are sure thats what hasn't happened then there are are other options. Am assuming you are using a windows pc? Sometimes the computer can get confused with regional language settings(different countries have different keyboard layouts)
If this setting gets changed it can cause problems so try
  1. Get to the Control Panel in windows.
  2. Double-click Regional and Language Options.
  3. Click the Languages tab.
  4. In the Text Services and Input languages pane, click Details.
  5. In the Installed Services pane, click any keyboard listed other than US (US or UK depending on where you live), and then click Remove.
  6. When the confirmation message appears, click Yes.
  7. Repeat step 5 until all listed keyboards except US or UK are removed.(Hopefully this will have solved your prob. If not borrow a friends keyboard, try it out on your pc. If you dont get the same problems with the borrowed keyboard then something is wrong with yours and it probably needs replacing)
Jul 01, 2009 | Computers & Internet
Wireless controller is constantly moving down
One of two things. First, when you turn on the power, do not have anything pressing against the joysticks. It will sometimes cause the problems you are describing. If that is not the case, I would assume you got something stuck under it or spilt something on it. Good luck.
Apr 28, 2009 | Microsoft Xbox 360 Wireless Controller
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Staining on LCD tv screen
The LCD screen is bad this may have been caused by presure exerted to the screen fracturing the cells of the LCD. any way the LCD is bad and needs replacing.
Dec 27, 2007 | Philips 32PT6441/37 32" TV
Color shadows
PVAT!Check for evidence of coolant leak on pcb's, If none found,replace convergence IC's,then align convergence in servicer mode.Check service literature for procedure.
Sep 02, 2007 | Hitachi 60UX58B 60" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
