Question about Sewing Machines
Puckering lower fabric when adding piping
I am using the old Elna jubilee (20 years old or more) that gave my daughter and don't remember how to lower the feed dogs. I am trying to do piping on a crib bumper and the bottom fabric is feeding in too quickly and puckering. How can I make the fabric feed more evenly. It is 2 layers of cotton with a corduroy piping in the middle thanks so much Karen
  • 111 Answers
Get yourself a Walking Foot
Posted on May 04, 2009
The bottom feed of my Elna 9000 which I bought about twenty years ago will not stay up, the plastic switch at the back of the machine appears to be broken.
The only to find out is to ask your service technician. Sometimes replacement parts are still available or they can pillage some older machines to find what is needed.
Sep 10, 2017 | Elna Sewing Machines
Walking foot for ELNA 9000 or Elna lotus zz please
SORRY FIXYA does not sell any products , check with a sewing machine company
Aug 17, 2017 | Elna Sewing Machines
Can I sew fine knits with my Bernina 830? What would I dial the machine to in order to avoid puckering?
Warning--leaving the presser foot up while sewing will not work because raising the presser foot releases the tension!!! You'll likely end up with a huge knot of thread to remove and possibly damaged fabric.
Fine fabrics present some issues for most machines but there are several things you can do to alleviate or even eliminate issues.
Be sure to use lightweight needles for knits (ball point). Use a good quality fine thread. Loosening the tension will help alleviate some of the puckering. In addition, using a wash-away stabilizer to add body to the fabric will help with puckering. (Even using paper under the fabric will be enough to remove puckering--however, it tends to dull the needle faster than usual--but a new needle is an inexpensive solution to an age-old problem. Also, using a roller foot, teflon foot, or walking foot may be beneficial in feeding the fabric. Some people will starch the fabric to add body.
Seam Puckering Industrial Sewing Thread Tension Coats Industrial
How to Prevent Puckering Sewing Machine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=13&ved=0ahUKEwjhhe_O2abSAhVQ0WMKHT1-AtAQFghSMAw&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Perfect Machine Tension Every Time Threads
Feb 23, 2017 | Bernina Sewing Machines
Singer model 2638 puckers fabric when sewing straight stitch. Have to manually keep fabric taut behind needle to get anything accomplished. Why does this occur and how can it be fixed?
If the fabric is puckering when stitching, usually it is because the tension is too tight. You may need to loosen both the top and bobbin tensions.
Another time the problem occurs is when sewing fine fabric (like chiffon). The fabric does not have enough body to lay flat, so it puckers. You can utilize a stabilizer to help give the fabric body (washaway or tearaway stabilizer, or even use light-weight paper such as adding machine tape or even toilet tissue). Sometimes some spray starch is enough to help it lay flat.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwih76G2yuHNAhVBVWMKHV-1DiEQFgggMAE&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A&cad=rja
http://www.beaconfabric.com/vindex.html?SelectingtheRightStabilizer.htm
http://www.coatsindustrial.com/en/information-hub/apparel-expertise/seam-puckering
Jul 06, 2016 | Singer Sewing Machines
Need help with tension as thr stiches are puckering.
If the fabric is puckering when you sew, it is most likely because the thread tension is too tight. Make sure you are using a brand-new needle compatible with your fabric--using a 70 or 80 needle and a lighter weight thread may work better as a 90 or higher needle is big enough that it can stretch the fabric before penetrating it, causing puckering.. Puckering also occurs more frequently when sewing light-weight fabrics and may necessitate using a walking foot or a stabilizer to help give the fabric more body as it is stitched (wash-away stabilizer would probably be good when sewing washable fabrics). Another thing that may cause puckering is when the bobbin is wound at a fast speed. Slowing down when winding the bobbin will reduce the amount of stretch added to the bobbin thread. If it is stretched going onto the bobbin, it will shrink back up when it is stitched to your fabric. Also check whether your machine has a presser foot pressure adjustment. The pressure should be lighter when sewing finer fabrics, ie silk, and heavier when sewing thicker fabrics like wool or denim.
How to Prevent Your Sewing Machine from Puckering Fabric Howcast
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjcuq2nkIPMAhXlxIMKHVgUAqUQFgg1MAU&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Stitching is puckering on lightweight fabric SEWING IN GENERAL
All About Needles
Apr 10, 2016 | Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
My elna overlocker 925 puckers fabric at pressure foot please how can i fix this?
This is usually caused by incorrect thread tension. Light weight fabric with the tension too high will pucker fabric. Thread that is too heavy or light for the fabric throws the tension off.
Feb 04, 2015 | Elna Sewing Machines
Elna sewing machine fabric is puckering
Check tension and threading up first, sounds like top tension or thread catching somewhere. Also have you changed the needle, i change mine for EACH new sewing project, needles go blunt and need replacing every 4-6 hours of sewing. Lastly, press seams as you go, this improves appearance and blends stitching into the fabric,
Mar 05, 2013 | Elna Sewing Machines
Uneven feeding on the elna jubilee
The fabric is puckering because of fabric slippage. The pressure of the foot is keeping the fabric from moving when the feed dogs move the lower layer of fabric.
I think this machine may have a pressure adjustment regulator on it. If it does.it is on the top left side,towards the back of the machine. It will be round and chrome color. Loosen the pressure and, if necessary, pull the fabric gently towards the rear while you are sewing.
A walking foot attachment will help but since it is so wide you may not be able to use it.A roller foot is an acceptable substitute but that may be too wide also.If everything else fails you will need to pin the layers together to keep them from slipping.
Hope this helps.
Sewman7
P.S. Please don't rate this post unless it solves your problem. Thanks
Apr 24, 2009 | Elna 1010
Brother Super Galaxie
Does it pucker when you are embroidering or just sewing in general? If its puckering when your embroidering it could be a few things. 1. no stabilizer 2. the fabric stretched in the hoop too tight. 3. check you tension
Oct 23, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
119 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
